Looking for the little brass ring in a steering column that has horn wire attached to it. Also need the roller that touches this ring as you steer. Mine is shot and is causing my horn to work intermittently. Does anyone have access to these parts. Havent been able to find brass ring or roller. Parts are in a 1970 cuda
two five zero 575 93fourty
chad
