Street/strip guys: Front ends...poly or rubber?? #1569685
01/27/14 08:14 PM
01/27/14 08:14 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Just what the title says, poly or rubber rebuild kits. 75% street, but I would think the poly stuff would be too stiff therefore hindering weight transfer.
Discuss.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569686
01/27/14 08:42 PM
01/27/14 08:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I went from Poly to hiem joints and will never go back. RMS tube uppers and strut rods. The only bushing I have in the front is poly and its in the lower control arm. Rides better on the road and leaves much better on the track.
68 Barracuda Formula S 340
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Bad340fish] #1569687
01/27/14 08:57 PM
01/27/14 08:57 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Have always been told you want rubber up front as opposed to poly since it is supposed to be less stiff and allow freer and smoother movement
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Bad340fish] #1569688
01/27/14 09:04 PM
01/27/14 09:04 PM
Renton Washington
Triple Threat Offline
Renton Washington
This is my set up as well.
RMS uppers,
stock lowers with Poly bushings
QA1 strut rods
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Triple Threat] #1569689
01/27/14 09:15 PM
01/27/14 09:15 PM
cudadoug Offline OP
cudadoug  Offline OP
Oh yea, I left out...OE everything up front. No tube control arms, etc.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569690
01/27/14 09:31 PM
01/27/14 09:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
One of the old tricks was to use bearings in the control arms for free movement, but that wouldn't be good for a street car.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: topside] #1569691
01/27/14 10:48 PM
01/27/14 10:48 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Looks like these would work. Possibly these upper and a lower rubber if you were concerned with the ride.
http://www.speedwaymotors.com/Control-Arm-Bushing-wcg.html
Getting old just means you were smarter than some and luckier than others.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Bad340fish] #1569692
01/27/14 11:21 PM
01/27/14 11:21 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
X3
Although mine is a Magnumforce unit. My uppers are poly, but all the rest are heim's and I would not hesitate to go that rout for any street car. A little maintenance now and then, and your good to go..
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Dragula] #1569693
01/28/14 12:16 AM
01/28/14 12:16 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I got rubber in the lower control arms, the rest of it is being changed over the winter to some stuff my buddy and I are making and is all heim mounted.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: SpareParts] #1569694
01/28/14 12:47 AM
01/28/14 12:47 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I used poly in my old Duster and had the weight transfer issue.....so....I took it apart again and broke out some sand paper and took a hair off the bushings and coated them with grease. Worked great after that..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569695
01/28/14 02:13 AM
01/28/14 02:13 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stock suspension and poly here.............
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Thumperdart] #1569696
01/28/14 02:28 AM
01/28/14 02:28 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
Same here, but greased
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Stroker Scamp] #1569697
01/28/14 03:01 AM
01/28/14 03:01 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I knew it.............no wonder my car doesn`t hook...........NO GREASE............
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Bad340fish] #1569698
01/28/14 03:14 AM
01/28/14 03:14 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
X4. But, I have rubber lowers.
The guy at RMS said to use rubber.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Von] #1569699
01/28/14 04:13 AM
01/28/14 04:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Basically all stock on mine. I did not go with the poly as its all rubber and stock suspension. I may consider changing to poly if I hear enough good about it that it would be worth it for me. Ron
Re: Street/strip guys: Front ends...poly or rubber?? [Re: 383man] #1569700
01/28/14 04:22 AM
01/28/14 04:22 AM
cudadoug Offline OP
cudadoug  Offline OP
Thanks guys...good info as usual. Funny though...as if right on cue my buddy stopped by tonight with his 73 cuda. He just redid the front end last month with poly parts. After about 200 miles it has developed a loud and annoying squeeeek coming from both side's upper control arms.
Decisions decisions...
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569701
01/28/14 07:04 AM
01/28/14 07:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Poly on my car, but it also goes around corners
I'm sure the car would hook better and be quicker if I took the sway bars off and changed the handling T-Bars to something smaller.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: 451Mopar] #1569702
01/28/14 11:43 AM
01/28/14 11:43 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
So has anybody tried the nylon LCA bushings as opposed to urethane?
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569703
01/28/14 12:17 PM
01/28/14 12:17 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Went 1.32 with all poly and all stock front end.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569704
01/28/14 12:44 PM
01/28/14 12:44 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
All stock rubber here.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
