Converting manual windows to power - 93 Ram #1569620
01/27/14 06:00 PM
01/27/14 06:00 PM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
Has anyone done this? I found a kit for about $350 but was curious if anyone has found a cheaper but still quality route to doing this? I realize Im kinda splitting hairs here since the regulators for some of the cars Ive worked on were only $100ish each so times 2 that's $200, but I also am not entirely sure on the quality of the kit. Thanks!
Re: Converting manual windows to power - 93 Ram [Re: Baxter61] #1569621
01/27/14 07:09 PM
01/27/14 07:09 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get the factory regulators, switching, wiring and go for it. I wouldnt try any aftermarket/offshore stuff..
I am truckless..
Re: Converting manual windows to power - 93 Ram [Re: 340SHORTY] #1569622
01/27/14 07:43 PM
01/27/14 07:43 PM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
were they available in 93 with power windows?
Re: Converting manual windows to power - 93 Ram [Re: Baxter61] #1569623
01/27/14 08:08 PM
01/27/14 08:08 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Got two '93 Ramcharger LE, both w/ PW. The 318 drivers side window broke yesterday, motor runs, no movement. You can slide the window up and down by hand about half way. I'll be looking into it soon, suspect stripped window motor gear.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Converting manual windows to power - 93 Ram [Re: 3hundred] #1569624
01/27/14 09:43 PM
01/27/14 09:43 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 93 one ton has one power window, the passenger side has never worked since I owned it. I bought a used door last year that was complete with everything for $50, might want to look into that route first.
JB Rhinehart, Realist
A-Body's RULE!
Re: Converting manual windows to power - 93 Ram [Re: Rhinodart] #1569625
01/27/14 10:12 PM
01/27/14 10:12 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
My 86 Ramcharger has power windows, and I have had an 84 with them also.
I cant say for sure, but they probably had them in 81 with the new body style.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Converting manual windows to power - 93 Ram [Re: Baxter61] #1569626
01/27/14 11:27 PM
01/27/14 11:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
80 was the first year for power windows. I swapped all the factory parts onto an 89 ramcharger that had crank ups. Took a couple of days and best part was the fact that the power window switches had a dotted line to cut out on back of door panels and that was also where the cranks were. Worked out perfect.
Re: Converting manual windows to power - 93 Ram [Re: buildanother] #1569627
01/29/14 10:25 AM
01/29/14 10:25 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I converted my '84 to power windows and locks using junkyard parts from an '89.
Re: Converting manual windows to power - 93 Ram [Re: TooMany62s] #1569628
01/29/14 02:26 PM
01/29/14 02:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 83 had them also.My motors went and I got something like 5 free from my buddys junkyard.They came out of 5th avenues.Only thing was the wiring was opposite from the Rams.Just switched the wires around and they worked great.Rocky
Chrysler Firepower
Re: Converting manual windows to power - 93 Ram [Re: TooMany62s] #1569629
01/29/14 11:59 PM
01/29/14 11:59 PM
Lehigh Acres, Florida
rickstershemi Offline
Dan....that is one clean good looking truck
Rickster
Re: Converting manual windows to power - 93 Ram [Re: rickstershemi] #1569630
01/30/14 06:00 PM
01/30/14 06:00 PM
Sacramento, California
retiredguy Offline
retiredguy  Offline
I'm in the process of changing my LRE from manual to power windows and door locks. I got all of the parts from a 89 Ram 250 Van. I took everything for the windows and locks, including the motors, solenoids, switches, relays and all of the wiring and connectors. All of this stuff cost me around $185 at pick n pull. I did the same thing on my 73 Duster and it turned out great. Good luck on your project.
Larry
Re: Converting manual windows to power - 93 Ram [Re: retiredguy] #1569631
01/30/14 09:12 PM
01/30/14 09:12 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Just for curiousity, I took a look on Rock Auto. About $50-60 for each regulator and about $40 for each motor. I don't know how complete the regulators are--I.E. do they need more small parts to make them work?
I figured I would just throw this out there.
I have door panels and switches so far for my conversion. One of these days I hope I can score the rest of the parts at a yard so I can change my '85 over.
Outcast Dodge guy.
Re: Converting manual windows to power - 93 Ram [Re: 85_Ram_4speed] #1569632
01/31/14 10:50 AM
01/31/14 10:50 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
It's been a long time since I converted mine using junk yard parts but I'm pretty sure I had to remove some mounting brackets and other misc parts from the donor truck.
Re: Converting manual windows to power - 93 Ram [Re: TooMany62s] #1569633
05/02/14 11:59 PM
05/02/14 11:59 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Any of you that converted want to sell your driver's side manual regulator? Or point to a source for a new one?
Re: Converting manual windows to power - 93 Ram [Re: bohmer2] #1569634
05/03/14 12:08 AM
05/03/14 12:08 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Check the LMC catalog thread. Pretty sure I saw regulators in there reasonably priced.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Converting manual windows to power - 93 Ram [Re: 3hundred] #1569635
05/03/14 01:12 AM
05/03/14 01:12 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Robert
Take the flat plate off the gear drive on the motor and replace the broke plastic pieces with steel ball bearings and it will work better than new..
Re: Converting manual windows to power - 93 Ram [Re: 3hundred] #1569636
05/03/14 10:54 AM
05/03/14 10:54 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Robert
Price wasn't bad, but they are listed as back ordered! That soon after the catalog release leads me to believe they don't have them yet.
Re: Converting manual windows to power - 93 Ram [Re: bohmer2] #1569637
05/15/14 12:15 AM
05/15/14 12:15 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Ive used the universal kits off ebay for converting manual to power. They are less than 100$ and super easy to install as all they do is actuate your stock manual window regulator. They can put more torq on that mechanism than you can by hand. Have em in 3 vehicles and so far so good. For the cost and hassle, I wouldn't fight with the stock stuff unless it was free.
