SLICKS....................... #1569567
01/27/14 04:52 PM
01/27/14 04:52 PM
State of confusion
Thumperdart Offline OP
State of confusion
Decided to step up and put a real tire on Thumper so, what`s the best slick in a 29" size on a 10" rim for a 3050 lb. BB car and I will street drive it...........thankxxx.
Re: SLICKS....................... [Re: Thumperdart] #1569568
01/27/14 05:08 PM
01/27/14 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you will keep the same tires on it all the
time... last time I heard the QTP was the best for
traction but have a somewhat shorter life span(which
is to be expected on a softer tire)
Re: SLICKS....................... [Re: Thumperdart] #1569569
01/27/14 05:10 PM
01/27/14 05:10 PM
Buy the biggest ones that will fit on your car
Re: SLICKS....................... [Re: MR_P_BODY] #1569570
01/27/14 05:11 PM
01/27/14 05:11 PM
State of confusion
State of confusion
I run those now but they are not a slick and a friend w/an 8.50 car went 1.34 60 ft. on these then went 1.23 on a et slick so that`s why I feel my car would improve plus I`m gettin back into street racing so I can make money instead of pay..............
Re: SLICKS....................... [Re: Cab_Burge] #1569571
01/27/14 05:15 PM
01/27/14 05:15 PM
State of confusion
State of confusion
I sold my 12" rims like a fool cos they rubbed and I know there`s an ideal tire to rim width ratio but feel I can get it done w/the 10" rims w/a real tire........
Re: SLICKS....................... [Re: Thumperdart] #1569572
01/27/14 05:19 PM
01/27/14 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont feel that because he got a improvement that you
should see any... I'm betting he has a better suspension
and better shocks.. so your not looking at apples to apples...
how long have your tires been on the car and what
was the best 60' when they were new
Re: SLICKS....................... [Re: MR_P_BODY] #1569573
01/27/14 05:24 PM
01/27/14 05:24 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you plan to run a true "slick".....and in that size range, there is ONE answer M/T. Put the 29.5 W on it, if it will fit. If not, use the 29.5 S (stiff sidewall). NO company has done more small tire development than M/T
A QTP will NOT 60ft as hard as a real slick, because the carcass is REALLY soft and tends to wad up, to make the treaded tire work better. The BEST 60ft on a treaded tire, will be a drag radial, but they are too hit and miss on a sketchy track and likely useless on the street most of the time
Monte
Re: SLICKS....................... [Re: MR_P_BODY] #1569574
01/27/14 05:26 PM
01/27/14 05:26 PM
State of confusion
State of confusion
Tires are about 2 years old and my sig was a 1.39 but my best at Irwindale was 1.36`s back to back and runnin 6.22`s before I freshoned it up. Now that my shocks are verticle it works WAY better on the street..........
Re: SLICKS....................... [Re: Monte_Smith] #1569575
01/27/14 05:29 PM
01/27/14 05:29 PM
State of confusion
State of confusion
Monte
Ya Monte several locals run that tire w/great success so maybe that`s the answer then we will see how the 8 3/4 holds up..........
Re: SLICKS....................... [Re: Monte_Smith] #1569576
01/27/14 07:19 PM
01/27/14 07:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
I am switching to M/T next time in a 14/32
Re: SLICKS....................... [Re: Thumperdart] #1569577
01/27/14 07:54 PM
01/27/14 07:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Monte
Oh boy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SLICKS....................... [Re: pittsburghracer] #1569578
01/27/14 08:47 PM
01/27/14 08:47 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My Valiant has M/T 29.5 11.5 on a ten inch rim. Been 1.27 on them running hi fives in the 1/8. Mine are not W or Stiff.
I'm having trouble holding the front end down cause its trying to hook so hard.
It puts on a show when you let go!
Re: SLICKS....................... [Re: Thumperdart] #1569579
01/27/14 09:14 PM
01/27/14 09:14 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
I have run the M/T on the Dart and switched to the Hoosiers and now a BIG fan of them. Better and more consistent 60'. In talking to them before I ordered, I was thinking of the radials and they talked me out of them. Shorter life but will perform better. Given my application they suggested I didn't need the radial slick.
If my wheels/tires fit on your car your welcome to make a pass or two to see what you think.
Hoosier 29.0/10.5-15W
Tom
Re: SLICKS....................... [Re: Dart Racer] #1569580
01/27/14 09:36 PM
01/27/14 09:36 PM
In the tower
RonTheAnnouncer Offline
In the tower
Last trip down south this past fall I couldn't believe how many guys were running Hoosiers. I thought someone must be giving them away, probably 2/3rds running them if not more. Anything from (1/8th mile) high 7 second to mid 5 second cars and a bit quicker.
Ron H.
"Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
Re: SLICKS....................... [Re: RonTheAnnouncer] #1569581
01/27/14 09:58 PM
01/27/14 09:58 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I live down south Hoosier 18192 10.5
Re: SLICKS....................... [Re: Dart Racer] #1569582
01/27/14 10:18 PM
01/27/14 10:18 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Dom I too have changed to a hoosier 29/10.5w/15 most of the time on my Dart.
This tire is the same size as a QTP 29/13.5/15. For me no real et change, but 60' is a little more consistant and reaction time is a little quicker and sidewalls have lasted longer. Still like my QTPs when I want the "Its just a street car" look.
"Just a Bracket car dressed up like a streetcar"
Re: SLICKS....................... [Re: Dart Racer] #1569583
01/27/14 10:20 PM
01/27/14 10:20 PM
State of confusion
State of confusion
Tom
Damn, now I`m confused........... Thankxxx for the offer but I don`t plan on racing at a track anytime soon.............
Re: SLICKS....................... [Re: Thumperdart] #1569584
01/27/14 11:54 PM
01/27/14 11:54 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Offer is open if you change your mind. My car is parked waiting on my engine to get back, so won't be running it until mid March. All of Feb is open for ya.
Re: SLICKS....................... [Re: Thumperdart] #1569585
01/28/14 12:12 AM
01/28/14 12:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Don't know if it's still true after all these years, but I saw some tests a ways back where M/T ET Streets were pulling virtually identical times to their ET Drag counterparts. If you still need a DOT-legal tire, this might be something to consider...
Re: SLICKS....................... [Re: Dart Racer] #1569586
01/28/14 02:10 AM
01/28/14 02:10 AM
State of confusion
State of confusion
Thankxxx again but a buddy of mine has some coin he wants to spend on me and bring to the streets for betting so he`s buyin and I`m not too proud to oblige. Brad, I tried the et-streets and for some reason my car didn`t like em but that was before my leaf mod so who knows plus the cops up here are cool about slicks on the street..........
