2.94-3.23 gears and an 833 #1569439
01/27/14 02:57 PM
01/27/14 02:57 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm trying to optimize my combo on a budget. I'm ready to swap my 6.1 hemi in, but I can't swing a 5 or 6 speed yet.
I've got several 8.75" chunks in 489 and 742 to swap to.
I'm going to be running a strong 6.1 hemi with a stock Sachs clutch and steel flywheel. I'll have more than enough torque to move my car.
Who here has run a 4 speed and 2.94-3.23 gears? I've got a 2.94 peg leg that I ran with a stock 440/727 and it was fine for the driving I do. (mostly highway) but now that I'm going to a new motor with my 4 speed, I'd like to take one step up in gearing.
I drive 18 miles to work and I'd like to get to the roadcourse eventually. Acceleration from a stop isn't a concern since it wont have a good tire any time soon.
Here is the info for Steff's motor...which will be very similar to my own. Torque wont be a problem.
Motor Details: Stock Short Block, Modern Cylinder Head ported 6.1 Heads, 358/240cfm @ .650 lift, Stock 2.08/1.58 Hollow Stem Valves, PAC Springs & related parts, Stock Rockers, Trend Pushrods, 5/16 x .080 wall, Performance Werks Racing Custom Hydraulic Roller to work with stock piston (no valve reliefs): 224/228 @ .050, .620/.640 lift , 112CL +2 , Drag Pack Intake, Proform HP950 Carb, Milodon Pan & Windage Tray, Firecore Prototype Coil Packs, 1 3/4 primary x 30” long dyno headers, ATI Drag Pack Damper, Meziere Remote Water Pump.
Dyno pulls were from 4500 to 6500 rpms.
Torque curve is very nice, starting at 472 ft. lbs. at 4540 rpm, peaking at 487 ft. lbs at 5258 rpm, then tapering off to 450.5 at 6454 rpm
Horse Power started at 408.1hp @ 4540 rpm & steadily climbing to a peak of 556.5 hp @ 6441 rpm.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569440
01/27/14 03:33 PM
01/27/14 03:33 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
I have a 4-speed Charger with 3.23 gears. I'd go no lower than a 3.23 for all around driving and fun. If you have a highway cruiser 2.94 would surely work to help with the gas mileage, but not so much with the fun factor.
Dan
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569441
01/27/14 03:42 PM
01/27/14 03:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What is your rear wheel diameter and size?
Re: 2.94-3.23 gears and an 833 [Re: autoxcuda] #1569442
01/27/14 03:45 PM
01/27/14 03:45 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Currently a 28" with my 2.94's. Its slow.
Will be going to a 26" with new wheels and tires.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569443
01/27/14 03:54 PM
01/27/14 03:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What's the top speed that at end of straight for the track you want to go to? Same track as Ucoog? What was his top speed?
Re: 2.94-3.23 gears and an 833 [Re: autoxcuda] #1569444
01/27/14 03:58 PM
01/27/14 03:58 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I bet about 130 down the front straight. He is shifting to 5th on his TKO. He is at Texas World Speedway. We were actually there this weekend. He gave some seriously expensive cars a very, very hard time.
I'd like to try at least a half mile standing course. I hope that with a 6600rpm redline I could go deep into fourth and keep accelerating.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569445
01/27/14 04:02 PM
01/27/14 04:02 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I did the vexer calculator just now. My redline is 156 with 3.23's, 275/40-17 and 1:1 @ 6600 rpm
130 mph is 5500 rpm.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569446
01/27/14 04:05 PM
01/27/14 04:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
need to make decesion on what you want to focus on.
For track 3.23's would seems to be ok if motor good to 6400. But I think you need a more accurate idea of top speed.
For speed trial 2.94's.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569447
01/27/14 04:57 PM
01/27/14 04:57 PM
AndyF Offline
AndyF  Offline
Tim's Valiant has 2.94 rear gears with a wide ratio 4 speed. Going all aluminum on the trans helped take a bunch of weight out.
Re: 2.94-3.23 gears and an 833 [Re: AndyF] #1569448
01/27/14 09:42 PM
01/27/14 09:42 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I have a 340 with a 4-speed and 3.23 rear and it's fine. Just a little clutch slip at take off to make it smooth and everything else is fine.
My engine does make 400 lb-ft (gross) at 2800 rpm though. Pulls hard once you get to 2000 rpm.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 2.94-3.23 gears and an 833 [Re: goldduster318] #1569449
01/27/14 11:56 PM
01/27/14 11:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ran an A833 with 2.94SG in my 87 Diplomat for years, just a 360 in front of it but I had no problems, 255/60-r15's. I'd imagine a 440 would have less problems.
Don't be the exception.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569450
01/28/14 12:44 AM
01/28/14 12:44 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Here are my thoughts:
833 1st gear = 2.47:1
tko600 1st gear = 2.87:1
viper t56 = 2.66:1
Rule of thumb for a drag car (not accounting for tire diameter) is 10:1 to 11:1 final drive in first.
833 first gear:
4.10 gear: 10.1:1 (51 mph 1st @ 6600, 26.2-26.5 tire height)
3.55 gear: 8.9:1 (59 mph)
3.23 gear: 8:1 (65 mph)
2.94 gear: 7.26:1 (71.7 mph)
tko600 2nd gear (1.89:1):
3.60 gear: 6.8:1 (76 mph)
tko600 1st gear:
3.60 gear: 10.3:1 (50 mph at 6600 rpm)
If you want to know what a 2.94 gear feels like in 1st, come drive my car starting from second.
FYI: Passon 5 speed will have a 2.64 1st gear.
2.94 gear: 7.76
3.23 gear: 8.5
3.55 gear: 9.3
You probably recall I've been looking at swapping to a 3.00:1 gear and a .82 OD in my tko.
8.6:1 1st gear (60 mph 1st gear)
Remember we've discussed many 'supercars' allow for 0-60 mph tests in 1st gear.
IMHO, I would pick your rear gear based on 1st gear redline and top gear redline. find a medium and call it good. If you get an OD added in, consider your cruising rpm at 75 as well.
I say go 3.23 or 3.55, (or 3.31 dana 60), but not 2.94.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569451
01/28/14 12:48 AM
01/28/14 12:48 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Thanks Alex!
I was short shifting the bone stock 6.1 hemi (for those who don't know, I blew my built motor at the Texas Mile). When I shifted into 5th (OD), the .64:1 OD didn't really do much for accelerating given the lack or aero. So 125-130 was probably about it on the straight.
C6 Z06 will do 145-150 max on that straight (Texas World Speedway). That's the fastest straight on a Texas road course to my knowledge (don't know about Texas Motor Speedway).
Re: 2.94-3.23 gears and an 833 [Re: Uhcoog1] #1569452
01/28/14 12:56 AM
01/28/14 12:56 AM
Lake Orion, MI
Lake Orion, MI
viper t56 = 2.66:1
The A-833 could also be 2.66:1 1st. The A-body ones are and also I believe most others. IIRC, the T/As/AARs and some 70-up HP B/E cars have 2.47:1
Re: 2.94-3.23 gears and an 833 [Re: goldduster318] #1569453
01/28/14 02:29 AM
01/28/14 02:29 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
viper t56 = 2.66:1
72 and up A-body 833's are 2.47 1st. And maybe sometime in 1971 too??? I think same goes for B/E bodies???
Re: 2.94-3.23 gears and an 833 [Re: autoxcuda] #1569454
01/28/14 03:07 AM
01/28/14 03:07 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
My 1970 833 shows to be a 2.65 first.
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569455
01/28/14 08:53 AM
01/28/14 08:53 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I ran [on the road course and street] a 2.66 1st gear 4sp in my AAR with 3.23's before Passon came out with the hemi 4sp OD trans. Then I ran 3.55's.
26 inch tall tire
In the 1/4 mile the 833 4sp was quicker than the hemi 4 sp OD. The car ran low 12's with a trap speed that said 11.90's. With the OD trans 12.60-12.80 On the back straight at the Glen the mph was the same with less shifting with the OD trans. 833/4-3-2-3-4 vs hemi OD/4-3-4
Re: 2.94-3.23 gears and an 833 [Re: ThermoQuad] #1569456
01/29/14 11:49 AM
01/29/14 11:49 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Could a 383/4 speed car have been geared with a 3.23?
Re: 2.94-3.23 gears and an 833 [Re: AlexP] #1569457
01/29/14 02:22 PM
01/29/14 02:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
From the factory? Yes.
Re: 2.94-3.23 gears and an 833 [Re: autoxcuda] #1569458
01/29/14 08:40 PM
01/29/14 08:40 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That was pretty much the standard combo unless you special ordered something different.
Isn't there an 833 with a 3.09 first?
Kevin
