Page 1 of 7 1 2 3 4 5 6 7
Mark stielow Camaro vs tim werners valiant #1568563
01/25/14 05:30 PM
01/25/14 05:30 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
I know this is not a apples to apples comparison but I am interested to see what would happen not enough mopars running a modern suspension without cutting the car all up
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568564
01/25/14 06:22 PM
01/25/14 06:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Define modern suspension.
Lots of well handling Mopars out there using upgraded stock type suspensions.
Don't be the exception.
Re: Mark stielow Camaro vs tim werners valiant [Re: Supercuda] #1568565
01/25/14 06:34 PM
01/25/14 06:34 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
Lots of well handling? Define what you would call well handling? If it can keep pace with a mark stielow Camaro then I would define that as well handling
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568566
01/25/14 06:58 PM
01/25/14 06:58 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Road course or autocross or both?
I think Tim's car is focused all on road course.
Of course Tim's car is actually Valiant.
The Stielow "Camaro" is 100% fabricated custom chassis vehicle that just happens to by-the-way have Camaro body hung over it.
With the aero and no compromise chassis, I'd guess the Stielow "Camaro" would be faster on a road course. I have no idea if Tim's Valiant would keep pace or not.
Re: Mark stielow Camaro vs tim werners valiant [Re: autoxcuda] #1568567
01/25/14 07:01 PM
01/25/14 07:01 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
Both and stielows cars use all detroit speed parts but still has factory firewall and floor
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568568
01/25/14 07:53 PM
01/25/14 07:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
According to CarCraft the suspension consists of:
Mark's car was a shell when he bought it, so rather than finding a stock subframe assembly, he went straight to the good stuff, calling friends Kyle and Stacy Tucker at Detroit Speed and Engineering to place an order for their front clip. While he was on the phone, Mark ordered a QuadraLink rear suspension kit as well as the rear minitub kit and front and rear sway bars for good measure. With adjustable, tubular control arms on all four corners working in conjunction with remote reservoir double-adjustable shock absorbers, Mark's car represents the ultimate in first-gen F-car handling.
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568569
01/25/14 09:38 PM
01/25/14 09:38 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Define which Stielow Camaro you want to talk about first. The guy has built fifteen of them.
FWIW, I seem to recall a recent comparions of Stielow's Red Devil (maybe his most famous one) to a modern ZL1. Net result was you could buy 2.5 new ZL1s and have some change left over for a daily driver compared to what it took to build the Red Devil Camaro.
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568570
01/25/14 09:39 PM
01/25/14 09:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Making the recesses to allow the triangulated 4 link upper mounts to clear is not a stock floor in my book. A more fair comparison would be the Red Devil against John Sandberg's AAR. That would be a nice a$$ kickn to witness.
Mopar to the bone!!!
Re: Mark stielow Camaro vs tim werners valiant [Re: 72Swinger] #1568571
01/25/14 10:44 PM
01/25/14 10:44 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
As usual you mopar guys totally missed this one stielows car has all stock sheet metal yes it has been mini tubed and has notches in the floor pans but do what he has within the same paramiters to a mopar the answer is no one has
Re: Mark stielow Camaro vs tim werners valiant [Re: TC@HP2] #1568572
01/25/14 10:45 PM
01/25/14 10:45 PM
AndyF Offline
AndyF  Offline
Tim probably has about $40K in his Valiant, Stielow's cars are usually $100K+ type of rides.
Tim's Valiant is still in my shop at the moment. It is getting close to firing up for the year, just need a few more parts to show up. The front suspension has a ton of custom built parts on it this time around so it will be interesting to see how it works. He finally got to a point where the stock stuff just didn't cut it anymore. The front suspension is now Kit Car style with a spline drive anti-sway bar built into the K-frame.
Re: Mark stielow Camaro vs tim werners valiant [Re: AndyF] #1568573
01/25/14 10:52 PM
01/25/14 10:52 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
So is it like a firm feel road race k frame? Show us what you did?
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568574
01/25/14 10:58 PM
01/25/14 10:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You obviously havent seen Sandberg's Cuda with it stock sheetmetal. And what do you mean "As usual you mopar guys totally missed this one" ?? If not a Mopar guy then why are you here posting? And the by the way, Mopars dont need completely new suspensions put under them to run with new cars like GM cars do so NO, your not gonna see anyone do what Stielow did.
Re: Mark stielow Camaro vs tim werners valiant [Re: 72Swinger] #1568575
01/25/14 11:04 PM
01/25/14 11:04 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
Well my personel car has many old school nascar tricks and then some plus a 630 hp small block will pull to 180mph on the straights with a lot left but not enough suspension to take it there so stock mopar spindles or control arms will not take it to the next level
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568576
01/25/14 11:59 PM
01/25/14 11:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
406ciW5, that sounds cool.
Show us what you did.
Re: Mark stielow Camaro vs tim werners valiant [Re: 72Swinger] #1568577
01/26/14 12:05 AM
01/26/14 12:05 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Bang on the money.
*Edit* Agree with Steve: can you post some pics of your car and what you got going on there?
Mo' Farts
Moderated by "tbagger".
Re: Mark stielow Camaro vs tim werners valiant [Re: Grizzly] #1568578
01/26/14 12:35 AM
01/26/14 12:35 AM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
I would say something very similar as what AndyF has going on
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568579
01/26/14 01:18 AM
01/26/14 01:18 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Cool, lets see some pictures 406ciW5 and share some ideas.
Re: Mark stielow Camaro vs tim werners valiant [Re: autoxcuda] #1568580
01/26/14 02:14 AM
01/26/14 02:14 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Those two cars are not even on the same planet, sorry to say. We competed at Optima and he had us covered by 18 seconds on a 2.2 mile course. We were the fastest Mopar there. Not saying the Valiant couldn't put it to us, but .....
The craftsmanship and engineering on his cars are second to none.
We are 10 years from having something that can run with cars like that. I have in the realm of 100k in mine......You can double that in Stielows. 700hp, anti-loc, traction control, please!
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Mark stielow Camaro vs tim werners valiant [Re: Viol8r] #1568581
01/26/14 09:17 AM
01/26/14 09:17 AM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
I would not say that mopars are 10 years form having that technology the new hemi can make that power and detoit speed is doing a charger with all there suspension tricks
Re: Mark stielow Camaro vs tim werners valiant [Re: kotacars] #1568582
01/26/14 03:00 PM
01/26/14 03:00 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Yeah I have been looking at their Charger project. Lots of tricks. I'd also like to hear more about your ride.
Damon
