Re: Do i need spring locaters on cast iron heads? [Re: Stanton] #1567882
01/24/14 07:34 PM
01/24/14 07:34 PM
Oklahoma
V
VoodooCLD Offline OP
V
Oklahoma
i had machined to fit viton seals, and had the original locating section cut so i could run dual valve springs.
I think you should post a pic of the seat. When the seat is cut for inner springs they usually only cut it back to the i.d. of the inner spring. Likewise when cutting the guide for viton seals, they usually only cut the guide.
The spring locators are all .060" thick. Instead of cutting the seats again you might consider getting retainers or valve locks that will give you .050" more spring height.
I sure wish he would have only cut the guides down to the inner diameter of the spring. I even brought him a full set of springs locks and seals when i had them cut. Too late now, gotta work with what i've got.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567883
01/24/14 11:12 PM
01/24/14 11:12 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
How many ways does it need to be said. YES, you SHOULD run a spring seat cup.
How nice of your to give no advice whatsoever and then come in aggressively stating your opinion.
Your input is not needed. Move along now.
You are only upset because you don't want to hear the truth. I didn't give my opinion because it has already been said. You need to use a locator to keep the bottom of the spring from walking. That is why there is normally a spring pocket. Since
yours has been removed, you need a new way of locating the bottom the spring.
Re: Do i need spring locaters on cast iron heads? [Re: drew72] #1567884
01/25/14 12:17 AM
01/25/14 12:17 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Post a pic of the seat - and one with a spring sitting in it.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567885
01/25/14 01:59 AM
01/25/14 01:59 AM
If the inner spring fits tight against the inner step of the retainer and against the outer spring or dampener yourprobally fine with those If the inner spring is loose on either of those two go with a cup or seat
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567886
01/25/14 03:35 AM
01/25/14 03:35 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
You DO NOT need to use any cup or bottom locator. Anytime they cut a mopar cast head for duel springs you lose the factory locator...I have a set of DC stage IV heads that have had a .750 roller cam with 275 lbs of seat pressure under them for 25 years with zero problems! The only thing that is needed is some sort of hardened shim, which you will probably use anyway to set the spring height.
Re: Do i need spring locaters on cast iron heads? [Re: loaderpro] #1567887
01/25/14 12:48 PM
01/25/14 12:48 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
I agree with loaderpro.
Not needed with iron.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Do i need spring locaters on cast iron heads? [Re: cb1289] #1567888
01/25/14 02:21 PM
01/25/14 02:21 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You may want to check installed height from the head seat to the retainer locked in place.If you have room for the cup or locater then use it.ie: if you sping suggested installed height is 1.890 and you distance with the retainer installed is 1.950 then use a .060 cup.If not use a single thin harden shim at the seat.Measure your height first to determine if you need to raise the spring or machine it to lower the spring.
Re: Do i need spring locaters on cast iron heads? [Re: B G Racing] #1567889
01/25/14 02:30 PM
01/25/14 02:30 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
If this is what you are concidering using, don't. Just use a hardened shim under your springs that fit the OD of the valve guide. I thought that I needed them and it cost me a oil pump and a pump cover. Could have been way worse.
Brian
Re: Do i need spring locaters on cast iron heads? [Re: '72CudaRacer] #1567890
01/25/14 02:31 PM
01/25/14 02:31 PM
Mooresburg, Tn
Mooresburg, Tn
another picture
Re: Do i need spring locaters on cast iron heads? [Re: '72CudaRacer] #1567891
01/25/14 11:20 PM
01/25/14 11:20 PM
Oklahoma
V
V
Oklahoma
Thanks for all the advice guys. I measured one side. 2 of the springs only need .030' shims, and 1 only need a.040" shim. Therefore the cups could cause me to need to get offset locks. The outside edge of the seals fit pretty flush with the guide, so i don't think there's much chance of them getting chewed up. There is only .050" of movement to be be had with the springs. And there is no pockets to jump out of. So i think i'll go ahead and skip the cups and just run shims (so far everyone needed a shim)
