Do i need spring locaters on cast iron heads? #1567862
01/24/14 03:08 AM
01/24/14 03:08 AM
Oklahoma
V
VoodooCLD Offline OP
V
Oklahoma
I'm running some 906 heads that i had machined to fit viton seals, and had the original locating section cut so i could run dual valve springs. I don't have any locating cups on right now, and from the one spring distance i've measured (only need a .030 shim). It doesn't look like i'll have enough clearance to run a locating cup.
I got hardened shims (although i'm not sure every spring will need one)
Can i run without locating springs
Cam is Hyrdraulic flat tappet
Advertised Duration 268/276, Lift .494/.513
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567863
01/24/14 04:45 AM
01/24/14 04:45 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
no;cups are use to protect aluminum heads from the steel springs from chewing them up. cast heads can take the beating.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567864
01/24/14 05:57 AM
01/24/14 05:57 AM
Cab_Burge Online work
Cab_Burge  Online Work
Check the new retainers and springs and see if the retainers will limit the springs(inner and or outers ) from moving around on the heads, if not you should do something to try and limit the springs from moving around on the heads at the upper RPM
Re: Do i need spring locaters on cast iron heads? [Re: Cab_Burge] #1567865
01/24/14 10:41 AM
01/24/14 10:41 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I've had this happen
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567866
01/24/14 11:44 AM
01/24/14 11:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think you should post a pic of the seat. When the seat is cut for inner springs they usually only cut it back to the i.d. of the inner spring. Likewise when cutting the guide for viton seals, they usually only cut the guide.
The spring locators are all .060" thick. Instead of cutting the seats again you might consider getting retainers or valve locks that will give you .050" more spring height.
Re: Do i need spring locaters on cast iron heads? [Re: Stanton] #1567867
01/24/14 01:33 PM
01/24/14 01:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If all the seat is cut flush you may want locaters or cups to insure the springs doesn't move and catch the seals especially if the ID is tight.With any iron or aluminium head it is advisable to install at least one thin harden shim to keep the leading edge of the spring coil from digging in to the head surface and creating filings.Soft shims will also get chewed up.
Re: Do i need spring locaters on cast iron heads? [Re: B G Racing] #1567868
01/24/14 01:36 PM
01/24/14 01:36 PM
Oklahoma
V
V
Oklahoma
What RPM's are we talking here. My cam is only good to 6200 rpm, and i'ts mostly a street car, so i won't be getting up there too often.
I'd really not have to modify it too much more. Do you guys really think it will be a problem?
Re: Do i need spring locaters on cast iron heads? [Re: DragDart360] #1567869
01/24/14 02:08 PM
01/24/14 02:08 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Me too.
They even jumped out of the pocket on one side.
1.63 pocket for 1.46 spring.
The springs got crocked so they went into the trash.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567870
01/24/14 02:16 PM
01/24/14 02:16 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What springs are you running ? I did the same thing as you , cut for viton seals and ended up with a flush spring seat. have your springs checked and see what happens to the pressure with .030 less installed height and run the cups without shims.
Re: Do i need spring locaters on cast iron heads? [Re: JohnRR] #1567871
01/24/14 02:36 PM
01/24/14 02:36 PM
Oklahoma
V
V
Oklahoma
Lunati#638-73100-16
Dual Valve Springs
OD: 1.450"
Inner ID: .730"
Seat Load: 125 lbs/in @ 1.850
Open Load: 325 lbs/in @ 1.250
Coil Bind: 1.110"
Rate: 333 lbs/in
Are the specs for my springs. The spring base is now cut flush (more or less) the base of the valve guide is .645" which is what a lot of shims are sized for, however i haven't found a cup that has that inner diamter.
I don't have a spring pressure gauge, and frankly after buying a micrometer gauge, i don't have the money to buy any more tools.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567872
01/24/14 02:45 PM
01/24/14 02:45 PM
Az
Crizila Offline
Crizila  Offline
Az
You gotta run locaters and add the distance back in with the correct retainers and keepers. Too great of a chance of the springs walking and eating the seals or worse, breaking.
Fastest 300
Re: Do i need spring locaters on cast iron heads? [Re: Crizila] #1567873
01/24/14 02:52 PM
01/24/14 02:52 PM
Oklahoma
V
V
Oklahoma
New question
Were can i find cups or locaters for a .645 valve stem diameter, with .730 ID and 1.450" OD spring?
So far i haven't found anything.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567874
01/24/14 03:22 PM
01/24/14 03:22 PM
New question
I buy and use Comp Cams spring seats and spring cups, two different ways to locate the springs Let us know if you don't find the ones you need, I'll look at the ones I have in stock also to see if any of them will work for your application
Re: Do i need spring locaters on cast iron heads? [Re: Cab_Burge] #1567875
01/24/14 03:50 PM
01/24/14 03:50 PM
Oklahoma
V
V
Oklahoma
New question
so far i have looked at comp, crane, and lunati locaters and cups, and still haven't found anything.If my valve guide was .630 i think i'd be in business, but for some reason the machinist cut them to .645. I didn't specify so i guess i can't complain too much.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567876
01/24/14 03:59 PM
01/24/14 03:59 PM
You can probally use Comp Cams # 4700-16 spring cups for your springs You could also have your machinest cut the guide O.D. down to .560 to use the #4776-16 spring seats instead of the cups
Re: Do i need spring locaters on cast iron heads? [Re: Cab_Burge] #1567877
01/24/14 04:24 PM
01/24/14 04:24 PM
Oklahoma
V
V
Oklahoma
Ok a few things. I remeasured my guides, and they are .625. So the .630 should work fine. However i was looking at the my spring retainer, and they have a dual step in them. The smaller step fits in the inner spring, and the larger step fits just inside the outer spring.
Will these do a good enough job of aligning the spring? Or do i also need a locater/cup.
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567878
01/24/14 05:27 PM
01/24/14 05:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Will these do a good enough job of aligning the spring? Or do i also need a locater/cup. IMO, you still need locator cups on the head side.
Fastest 300
Re: Do i need spring locaters on cast iron heads? [Re: VoodooCLD] #1567879
01/24/14 07:15 PM
01/24/14 07:15 PM
JohnRR Offline
JohnRR  Offline
They will locate the TOP of the spring fine , the BOTTOM , not so much ...
Re: Do i need spring locaters on cast iron heads? [Re: JohnRR] #1567880
01/24/14 07:21 PM
01/24/14 07:21 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
How many ways does it need to be said. YES, you SHOULD run a spring seat cup.
Re: Do i need spring locaters on cast iron heads? [Re: drew72] #1567881
01/24/14 07:29 PM
01/24/14 07:29 PM
Oklahoma
V
V
Oklahoma
How nice of your to give no advice whatsoever and then come in aggressively stating your opinion.
Your input is not needed. Move along now.
