Are your 1st gen headlights dim?
#1566929
01/22/14 10:25 AM
01/22/14 10:25 AM
Guitar Jones
Mine were, I was looking at some alternative lighting but decided to hold off, then the headlights cut off and came back on one night. I knew the switches have a circuit breaker in them so I replaced the switch. Wow, BIG difference. It never occurred to me that there are contacts in these old switches and they were dirty. Working on new computer controlled stuff everyday I tend to forget how the old stuff worked.
I took the old switch apart and the contacts were very dark. Just thought I'd pass that on to you all.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Are your 1st gen headlights dim?
[Re: Guitar Jones]
#1566930
01/22/14 11:33 AM
01/22/14 11:33 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Shoot, that's pretty good timing! I've been noticing mine getting dimmer and figured maybe the alternator wasn't doing it's job. I've never taken a switch apart. Can you just clean it up with steel wool or compressed air or what? Thanks.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1566931
01/22/14 11:40 AM
01/22/14 11:40 AM
Guitar Jones
It's riveted together into blind holes so you probably can't put it back together but the switches are cheap, probably $20 or so. I paid $12 for mine but my GF works for CarQuest and gets parts for cost.
edit: Just looked up my switch on line, lists for $20.36 part# 55222.
[Re: Guitar Jones]
#1566932
01/22/14 01:20 PM
01/22/14 01:20 PM
Posts: 15,487 Florida
scratchnfotraction
I have found the rivits holding the blade/spade on the switch loose and cuased it to heat up burning the plastic plug on them before. low idle and alt output does not help anything either. I now idle my trucks up at night with lights on till it has the no dim headlights at idle. only a couple hundred rpm over what I like but no more discharging at a redlight at night. I think I will go have a look at the switch in my 85 truck now... it is 29 yrs old
[Re: scratchnfotraction]
#1566933
01/22/14 01:30 PM
01/22/14 01:30 PM
Guitar Jones
Yeah mine was 22 years old. I'd post a pic but I can't at work.
[Re: Golden-Arm]
#1566935
01/23/14 10:28 AM
01/23/14 10:28 AM
Guitar Jones
you think they're bright now, add a set of relays at the headlights.
I've been considering that too.
[Re: Guitar Jones]
#1566936
01/24/14 12:55 PM
01/24/14 12:55 PM
Posts: 1,357 central Florida
VL21
central Florida
New switch was cheap, amazin Amazon is sending me one out, I am hoping it will help with the dim dash lights, so far no headlight problems. Back in my misspent youth I had a 64 Sport Fury, and got some "High power headlights" thru JC Whitney, turns out they were aircraft landing lights. I ground off the alignment lugs and put them in the high beam holes (same size) and was amazed! It would light up from one end of my little town to the other! On my first long distance trip, across Canada, I had occasion to leave the high beams on for an extended time ... that is when I learned about the circuit breaker built in ...after 1/2 hour the lights would flicker off/on once, then 15 min later again, then about 7-8 min again ... Finally figured out all I had to do was dim the lights for a couple minutes once in a while and I was good to go, problem solved! Any other time high beam use was short enough that it wasn't a problem.
It takes gasoline to interest me.
[Re: VL21]
#1566937
01/24/14 03:06 PM
01/24/14 03:06 PM
Guitar Jones
My dash lights got brighter but I cleaned my cluster and replaced all the dash bulbs when I replaced the switch so I don't know if the new switch helped that or not.
