torsion bars-new or re use the old ones? #1566768
01/22/14 01:20 AM
01/22/14 01:20 AM
new jersey
Black 69 Beeper Offline OP
new jersey
i have the front suspension out of my 69 road runner and i have everything new except the torsion bars. i media blasted them and there doesn't seem to be anything wrong with them. do i re use them or buy new. do they go bad? opinions?
Re: torsion bars-new or re use the old ones? [Re: Black 69 Beeper] #1566769
01/22/14 01:26 AM
01/22/14 01:26 AM
IN
ahy Offline
ahy  Offline
IN
If they don't have deep scratches or dents that can't be dressed out or other visual problems they should be fine for re-use.
Are they the size/stiffness you want? Different question.
Re: torsion bars-new or re use the old ones? [Re: ahy] #1566770
01/22/14 02:30 AM
01/22/14 02:30 AM
Everything that Ahy said
Re: torsion bars-new or re use the old ones? [Re: RapidRobert] #1566771
01/22/14 07:46 AM
01/22/14 07:46 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
if you have new everything i would think about upgrading the bar to a bigger size.not hat they go bad,just a suspension upgrade.
Re: torsion bars-new or re use the old ones? [Re: mcmopars] #1566772
01/22/14 10:47 AM
01/22/14 10:47 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
if you have new everything i would think about upgrading the bar to a bigger size.not hat they go X2bad,just a suspension upgrade.
Re: torsion bars-new or re use the old ones? [Re: Dons Dart] #1566773
01/22/14 11:43 AM
01/22/14 11:43 AM
Southern Illinois
W
wedgedave Offline
wedgedave  Offline
W
Southern Illinois
If your building a drag car I'd go with the 6 cylinder bars ,If it's a street car I'd go with a good pair of standard bars with no damage. Clean them and then coat them with a good epoxy paint or powder coat them. Be carful and repair any nicks or any imperfections in them first, They will fracture if their's any kind of damage, don't ask me how I know this.!!!!
Re: torsion bars-new or re use the old ones? [Re: wedgedave] #1566774
01/22/14 12:36 PM
01/22/14 12:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What causes torsion bars to bow? Its a straight shot fom the crossmember to the LCA and all they do is twist so what would cause them to bow? Almost every used set I've seen is bowed!
Sorry to hijack but this could be relevant to the OP.
Re: torsion bars-new or re use the old ones? [Re: Stanton] #1566775
01/22/14 04:11 PM
01/22/14 04:11 PM
Southern Illinois
W
wedgedave Offline
wedgedave  Offline
W
Southern Illinois
I read the post again and saw nothing about bowed or bent ???? Have no idea of what your referring to. I have been jacking with T bars all my life and never saw one bent or bowed only broken (IE) snapped.
Re: torsion bars-new or re use the old ones? [Re: wedgedave] #1566776
01/26/14 03:27 AM
01/26/14 03:27 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Maybe he means the strut rods?
T bars can go bad over time. If you set the ride height and it keeps dropping back to where it was, they are probably worn. The crossmember socket can also wear and cause the bars to settle in after a little ride time, but then they should stay put. Later models were "wall drive."
Re: torsion bars-new or re use the old ones? [Re: Montclaire] #1566777
01/26/14 03:43 AM
01/26/14 03:43 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I would never powder coat the hex ends...
JB Rhinehart, Realist
A-Body's RULE!
