I.D. this flywheel ?
#1565598
01/19/14 08:33 PM
01/19/14 08:33 PM
Posts: 756 North Florida
RebelDart
super street
super street
North Florida
I was told for an internal balanced 340 , it's 130 tooth and I have a 1970 340 I'm changing from auto to standard ..... even if it ain't right I got it for cheap but appears neutral balanced which I'll confirm when re-surfaced .... thanks
Re: I.D. this flywheel ?
[Re: RebelDart]
#1565601
01/19/14 08:35 PM
01/19/14 08:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Gonna say not internal balance here.
[Re: RebelDart]
#1565603
01/19/14 09:06 PM
01/19/14 09:06 PM
Supercuda
About to go away
About to go away
up yours
Somewhere on this site is a set of diagrams showing the various external balance flywheels, I cannot find it. If I do, or someone else has the link, post it.
[Re: Supercuda]
#1565606
01/20/14 04:57 PM
01/20/14 04:57 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You gotta remember that these parts are cast and can have heavy/light spots just from the casting process. I've seen cast parts from the factory that look like swiss cheese from so many balancing holes and others with hardly any. IOW, all those balancing holes ganged together could be original neutral balance holes.
[Re: fastmark]
#1565613
02/02/14 09:16 PM
02/02/14 09:16 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
IMO, that is not a factory flywheel. It is flat across the back. The OEM ones I have are rasised where the crank hub mates. And it has too many patterns for clutches. I would say you have an aftermarket flywheel that has been balance for an external motor of some kind. Who know what CID?
, It's an aftermarket wheel with patterns for Borg and Beck ... which is the style Chrsler usrd ... and the Long style which was manily used by Ford.
You have it , have it balanced neutral and you are good to go .
