8 3/4 with no chuck - roller??? #156552
11/25/08 03:39 PM
11/25/08 03:39 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Is there a quick trick to be able to move a car equipt with an 8 3/4 but with no chuck?? I imagine a section of pipe to connect the 2 free floating axle ends. Any off the shelf size of pipe work?? Perhaps a section of blackpipe??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 8 3/4 with no chuck - roller??? [Re: CJK440] #156553
11/25/08 04:06 PM
11/25/08 04:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what axle bearings? how much moving around ?
I would try a piece of PVC ?
Re: 8 3/4 with no chuck - roller??? [Re: CJK440] #156554
11/25/08 04:11 PM
11/25/08 04:11 PM
bought a car onece with no chunk (68 coronet) rolled it up on the trailer slowly, had my dad and my brother on each side to make sure the axels werent creaping out, worked fine, just dont go to fast,
Re: 8 3/4 with no chuck - roller??? #156555
11/25/08 04:13 PM
11/25/08 04:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it was an 8 3/4 the axles won't creep out since they are PRESSED into the bearings and the bearings are bolted to the housing ...
Re: 8 3/4 with no chuck - roller??? [Re: CJK440] #156556
11/25/08 04:17 PM
11/25/08 04:17 PM
Creedmoor, NC, USA
74Charger Offline
74Charger  Offline
Creedmoor, NC, USA
I'm talking from memory and don't do this every day, but how could they come out?
Nothing in the center chunk keeps the axles in if IRC. I thought the bearing retainers and locks held the axles in the housing. I don' think I would tow it in this state, but certainly you should be able to roll it.
Re: 8 3/4 with no chuck - roller??? [Re: 74Charger] #156557
11/25/08 04:29 PM
11/25/08 04:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The chuck keeps the bearings centered on the races . towing no , but some movement .
I have a ton of chucks , I would probably just set one up with a one legger carrier and no ring and pinion .
Re: 8 3/4 with no chuck - roller??? [Re: 74Charger] #156558
11/25/08 04:30 PM
11/25/08 04:30 PM
The axles are bolted in as said & just connect the 2 axles with a piece of pipe & you'll be fine for moving it around the yard
Re: 8 3/4 with no chuck - roller??? [Re: RapidRobert] #156559
11/25/08 05:20 PM
11/25/08 05:20 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I just want to roll it back out of the garage so I can pull the motor out of it but have a better idea. Pull the motor first then yank the chuck.
Re: 8 3/4 with no chuck - roller??? [Re: RapidRobert] #156560
11/25/08 07:01 PM
11/25/08 07:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, if you want to be more stable throw a 1 1/2" spacer in the pipe to duplicate the thrust block.
Re: 8 3/4 with no chuck - roller??? [Re: John_Kunkel] #156561
11/26/08 03:38 PM
11/26/08 03:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
1" X 1" ANGLE IRON WITH 2 HOSE CLAMPS. EASY TO INSTALL WORKS FOR SHORT DISTANCES.
DOUG
Re: 8 3/4 with no chuck - roller??? [Re: dvw] #156562
11/26/08 09:31 PM
11/26/08 09:31 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: 8 3/4 with no chuck - roller??? [Re: Lefty] #156563
11/29/08 12:50 AM
11/29/08 12:50 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
I towed a van with out a center section 35 miles on the interstate. I'm better I could have gone longer!
