8 3/4 with no chuck - roller???
#156552
11/25/08 03:39 PM
11/25/08 03:39 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Is there a quick trick to be able to move a car equipt with an 8 3/4 but with no chuck?? I imagine a section of pipe to connect the 2 free floating axle ends. Any off the shelf size of pipe work?? Perhaps a section of blackpipe??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 8 3/4 with no chuck - roller???
[Re: CJK440]
#156554
11/25/08 04:11 PM
11/25/08 04:11 PM
bought a car onece with no chunk (68 coronet) rolled it up on the trailer slowly, had my dad and my brother on each side to make sure the axels werent creaping out, worked fine, just dont go to fast,
#156555
11/25/08 04:13 PM
11/25/08 04:13 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
If it was an 8 3/4 the axles won't creep out since they are PRESSED into the bearings and the bearings are bolted to the housing ...
[Re: 74Charger]
#156557
11/25/08 04:29 PM
11/25/08 04:29 PM
JohnRR
U.S.S.A.
I'm talking from memory and don't do this every day, but how could they come out?
Nothing in the center chunk keeps the axles in if IRC. I thought the bearing retainers and locks held the axles in the housing. I don' think I would tow it in this state, but certainly you should be able to roll it.
The chuck keeps the bearings centered on the races . towing no , but some movement .
I have a ton of chucks , I would probably just set one up with a one legger carrier and no ring and pinion .
[Re: 74Charger]
#156558
11/25/08 04:30 PM
11/25/08 04:30 PM
RapidRobert
The axles are bolted in as said & just connect the 2 axles with a piece of pipe & you'll be fine for moving it around the yard
[Re: RapidRobert]
#156559
11/25/08 05:20 PM
11/25/08 05:20 PM
CJK440
Ansonia, CT
I just want to roll it back out of the garage so I can pull the motor out of it but have a better idea. Pull the motor first then yank the chuck.
