Any advice on Panther Pink paint? #156514
11/25/08 01:18 PM
11/25/08 01:18 PM
Farmington, CT
KISSAlien Offline OP
Farmington, CT
My Challenger needs to be redone. Any advice on paint brand to use and what process to follow?
I'd love an original single stage enamel but I realize that may not be practical. I try to only drive the car in nice weather but I do drive it as opposed to trailering it. It doesn't get washed unless I get caught in the rain. I do use a spray shine on it and a California duster.
Thanks for your opinions and advice.
Re: Any advice on Panther Pink paint? [Re: KISSAlien] #156515
11/25/08 01:52 PM
11/25/08 01:52 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
PPG DCC single stage urethane???? PPG Delstar is acrylic enamel. It's ok, but I bet the urethane paints last longer and will be more durable.
I had the engine compartment and trunk done with DCC in FJ5. I bought base clear for the outside, but probably would have been fine just using the single stage. It's a non-metallic color, just like your pink, so you can sand and buff it. I would not do single stage paint on a metallic color.
Re: Any advice on Panther Pink paint? [Re: KISSAlien] #156516
11/25/08 02:27 PM
11/25/08 02:27 PM
Kirkland, Washington
Pacnorthcuda Offline
I would stay with a single stage myself. It will actually make for a more correct look, and its plenty durable--wax it once in awhile. I would also compare a few actual samples, Panther Pink is a color that if slightly white washed looks horrible (and I have seen several cars that end up this way) but if its intense enough (blues and black tint toners) is really cool. Different paints WILL have slighly different appearances.
Back in 1994 I actually had Sherwin Williams Automotive custom blend my own version (slightly more black) to acheive the look I wanted. Its a pain, and I wouldn't recommend it for a 'correct' FM3 car, but it makes for a GREAT look.
Re: Any advice on Panther Pink paint? [Re: Pacnorthcuda] #156517
11/25/08 02:43 PM
11/25/08 02:43 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I liked the R-M Diamont base and clear we used clear flowed out nice on the areas that could not be sanded and buffed{like underside and engine bay}
Re: Any advice on Panther Pink paint? [Re: 340SIX] #156518
11/25/08 05:45 PM
11/25/08 05:45 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
If the plan is to wetsand and buff the final finish there's no use in using single stage, base clear is much more user friendly and the end result is more fade resistant.My point is if you water sand and buff the end result will look the same. I would recommend PPG or R-M Diamont. I used diamont on the Bee and it was very nice to work with.
Re: Any advice on Panther Pink paint? [Re: KISSAlien] #156519
11/25/08 06:22 PM
11/25/08 06:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ken......while I'm a big user of dupont products, and like the high glamour finish of the Dupont BC/CC Chroma Priemier line,.......If your searching for a single stage finish, to look "factory",.....I'd recommend you get the "pink", in Duponts IMRON line,....a real tuff single stage finish, not for "beginners",....IMRON is very tuff to wetsand and buff, if you have a booboo!, it can be done, but best to avoid if possible,.....Moulin Rouge/ Panther Pink mix formula is available in IMRON
Re: Any advice on Panther Pink paint? [Re: DAYCLONA] #156520
11/28/08 06:41 AM
11/28/08 06:41 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Agree with much of what was said above. I used PPG DC single stage.
You WILL find that supposedly the SAME PP color is different from different sources. Some shades look too blue, some too white. If you have ever seen two PP cars near each other at a show I'll bet many times they looked different.
My number 1 priority was getting the correct color (because that is what I liked, not because my car is original. But also why have it PP if it is actually going to be a different color?).
I had samples from different brands and none of them looked "right" - a very subjective measurable of course. However I did see a car at a show in Calif once which did look spot-on and I talked to the owner. He had had an original untouched sample (i.e. unfaded part of his original car) and had found that PPG was a dead match
That was good enough for me....so I went ahead and used it.
The PPG/Ditzler code is 2260
BTW, it seems a rather strange color (no, not because it is pink!). It really looks a different color in different lighting, and my painter also told be it was a bit like a metallic when it came to color matching (i.e. he thought it was very difficult to blend-in a part panel)
Re: Any advice on Panther Pink paint? [Re: Gavin] #156521
11/28/08 08:27 AM
11/28/08 08:27 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I am by no means a paint expert.. But this A12 Bee was done in single stage Glasurit. The finish is absolutely perfect, and this paint is legendary for it's toughness.
Re: Any advice on Panther Pink paint? [Re: KISSAlien] #156522
11/28/08 11:46 AM
11/28/08 11:46 AM
Ken: Your car is painted in Sherwin Williams. At that time it was the only paint that was close to being correct. However it was painted more than 20 years ago. Getting the correct colour will be the hardest challenge especially with clear coat and FM3 doesn't look nice unless it is the exact correct hue.
The paint was a problem on that car, the painter used SW colour then he clearcoated it, I'm not sure what he clearcoated it with. I let the car sit for a month and then I couldn't get ahold of the painter to wetsand and buff it (later turned out he was in jail). I checked with a bunch of shops and finally decided to wetsand and buff it myself. As soon as I touched sandpaper to the clear I got colour so something went wrong as the colour had mixed in with the clear. At that time all of the Pro buffing products would not bring the gloss back, what did bring the gloss back a bit was old fashioned Turtle wax polishing compound. I finally got ahold of the painter and arranged to have the car repainted but he died in a plane crash before repainting it. Anyway just a bit of sordid history on your car.
I believe it was recleared after I sold the car and the rocker moldings removed at the same time.
Sheldon
Re: Any advice on Panther Pink paint? [Re: HPMike] #156523
11/28/08 03:20 PM
11/28/08 03:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Super nice Bee! there Mike .....and yes Glasurit single stage is very popular with restorers looking for single stage paints,.......however a lot of formulas to mix "properly" have been "lost", or altered, and the original colors are no longer really represented, plus too many "kids" mixing paint nowadays,.....they can do it, but they know not, what they are doing,......when I did a FM3 car, Panther Pink/ Moulin Rouge was "tuff" to get right,.....I spent many a days in different paint shops, testing mixes, and sprayouts,......Dupont BC/CC chroma primere and Duponts Imron were the only formulas that had the right amount of "color/ light" shift present in them.....
When I paint a car, I like it to look original in color, but yet have some "effect" to the paint, otherwise it looks rather "dull".......
F6 was another one of those "tuff" colors to get "right",.....
Another side to paint/color match as well, is the prep, baseshade on the body,...plus "technique" and coverage in painting can alter the finish, or effect
Re: Any advice on Panther Pink paint? [Re: DAYCLONA] #156524
11/28/08 03:27 PM
11/28/08 03:27 PM
340SIX Offline
340SIX  Offline
I compaired the R-M base clear in limco and diamount as well as some PPG laqure and they were close to being the same. in fact I used some of the laqure in a spt or 2 in the truck area that was misssed when we shot the R-M base clear and it was realy realy close but was also cleared
Re: Any advice on Panther Pink paint? #156525
11/28/08 03:40 PM
11/28/08 03:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sheldon
.....Sherwin Williams is indeed a good match color/shade wise,....but didn't offer an "effect" to it, being able to "shift" slightly in different light or reflective influence,.......on the other hand, Dupount BC/CC chroma primere had that "effect"......on one of my customers FM3 cars, it was one of the reasons I went with that instead,.....while the SW was indeed a good match, it had a rather "dead" look to it ........plus IMHO SW is a rather "sub-par" automotive paint,......I know! I'll hear about that one!
Re: Any advice on Panther Pink paint? [Re: KISSAlien] #156526
11/28/08 04:45 PM
11/28/08 04:45 PM
Tooele Utah
SamB Offline
SamB  Offline
Tooele Utah
I prefer a base coat/clear coat system.I painted my 71 Charger R/T back in 1991.I used Glasurit single stage then wet sanded and cleared over the single stage then wet sanded again then buffed it out.The paint job is almost 20 years old and still looks like it was painted yesterday.Having a clear coat makes it much easier to take care of and also if you needed to do a repair it is much easier to spot and blend>Most restoration shops are also moving towards base/clear coats.Not by choice but because of VOC regulations.Shops must comply with changes or get fined.I now spray with ICI Autocolor a line that PPG now owns which is used on most European cars.Most paint shops will work with you on a color match but they will probably charge for that extra service.
Sam
Re: Any advice on Panther Pink paint? [Re: SamB] #156527
11/28/08 05:41 PM
11/28/08 05:41 PM
340SIX Offline
340SIX  Offline
I wonder how close the PPG paint chips are in the books?
Re: Any advice on Panther Pink paint? [Re: DAYCLONA] #156528
11/28/08 07:40 PM
11/28/08 07:40 PM
I agree with S-W not exactly being top notch paint. BTW that FM3 looked purple under flouescant lights, that was the coolest stock colour ever.
Sheldon
Re: Any advice on Panther Pink paint? [Re: 340SIX] #156529
11/28/08 08:44 PM
11/28/08 08:44 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
The factory used Electrostatic guns, and I suspect that caused a lot of issues regarding colors and the way they shift etc.
A sure sign that somethings different is how the paint lays on the firewall where it joins the trans tunnel. A spray gun tends to have a larger overspray pattern there.
I heard once that reversing the polarity on a metallic will change the lay of the flakes for an imperceptible changes that makes color matching and behavior hard to duplicate. Does anyone have any insight or experience?
Re: Any advice on Panther Pink paint? [Re: KISSAlien] #156530
11/28/08 09:49 PM
11/28/08 09:49 PM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
Ken why don't you call Ken Katarynchuk and ask him what paint etc he used on his FM3 R/T SE. The car turned out absolutely incredible. He won the Mr. Norms award at the Belvedere plant show this summer. It's just too bad it wasn't completed in time for the All Chrysler Nationals at Carlisle when all the Pink cars got together.
It would be great to see both of your cars together especially since they both sold new out of the same dealership in Calgary.
Ken and I were parked next to each other at a local show this summer and it was hilarious listening to all the "experts" divulge their knowledge about Pink cars
One thing for sure, it attracted every babe at the show.
Doug Lepak
Re: Any advice on Panther Pink paint? [Re: stwheels] #156531
11/28/08 10:33 PM
11/28/08 10:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This car was also painted with Sherwin Williams back around 93 still looks like new....& it definately changes in different light....
Re: Any advice on Panther Pink paint? [Re: 1_WILD_RT] #156532
11/28/08 11:26 PM
11/28/08 11:26 PM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
I used dupont BC/CC, notice the change in color depending on the light.
Re: Any advice on Panther Pink paint? [Re: RT_6_PakShaker] #156533
11/28/08 11:28 PM
11/28/08 11:28 PM
Soldotna,Alaska
super street
super street
Soldotna,Alaska
Later in the day with overcast
