Re: Hearing this more and more....
[Re: 383man]
#1565091
01/19/14 08:24 AM
01/19/14 08:24 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'm building a 420" gen III as we speak. Plenty of crank,rod and piston choices for them. I'm done making excuses. The LS7 is a cnc'd head from the factory, you put it up against a cnc'd Apache or even 6.1 head and it is behind. The main advantage an LS guy has is cheapness and aluminum blocks for weight savings. Other than that they can keep them.
Mopar to the bone!!!
[Re: MR_P_BODY]
#1565092
01/19/14 10:35 AM
01/19/14 10:35 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I say who cares ? Sure as heck not me as I will never put a Chevy eng in a Mopar to start with. Thats because I like 60's and 70's muscle cars and the LS whatever you guys are talking about is not even in my vocabulary. Now the LS6 Chevell 454 is a nice 70 muscle car eng and I like it in a Chevy. Myself I dont like putting new modern engines in old 60's and 70's muscle cars. The guys that are into the new stuff including that LS whatever eng then good for them but not me. If I see a 69 Camaro with a new modern GM eng at the track or a car show I dont even look at it. Ron
Ron I agree, but we're dinosaurs. I grew up with Mopars, my Uncles had them. Plus in the late 70's they could be bought cheap. But what about now? Honestly, if you were young with limited funds and bit by the go fast bug could you afford Mopars? You can buy a 80-90's Camaro for almost nothing. Add a junk yard LS, a turbo and go fast cheap! Plus there are a ton of aftermarket parts for them. How about the new Hemi? How many aftermarket blocks have you seen? Heads? Intakes?Engine controllers? You get my point.
Please don't take me wrong, I love my Mopars and have NEVER owned a GM. But.....if I were starting over with nothing and wanted to go fast it probably wouldn't be a Mopar. I wouldn't be able to afford them.
Your right.... a LOT of Mopar people have that dinosaur mentality ... I'm all Mopar but to say I would never put a modern hemi in a older car is down right backwards... most of the dinosaur guys would say... "it doesnt look right" BULL.. its just different.. if I find one its going into something that I own.. I might even pull that big heavy BB out of my 38 Ply and put a new hemi in it with OD and all... Hell I'm old and I still look at what goes fast and cheap is a plus, so the new hemi does fall into that.. sure you can start throwing bucks at it to go faster but stock in a light car will stomp on MOST BB on the street
Keep in mind that mega squirt has a plug and play system that bolts to the factory sensors that will run a G3. It even comes with a base tune. Not bad for 1800. Matt
[Re: Streetwize]
#1565093
01/19/14 11:31 AM
01/19/14 11:31 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
This talk of what is the cheapest,,,some say they are going to take out their current motor and replace it with a G3/LS because it's 'cheaper'..?? If you leave the motor in that you have now= NO COST!! I think there are a LOT of people that want a G3, but don't want it to look like they are 'betraying' their past history as a Mopar person. I know it was hard for me to finally admit that the G3 is a much better power producer than the normal LA with budget heads/parts. In fact, I have been telling a lot of my local small block Chevy dirt track racers to start thinking into the future, and seriously look at the LS motors,,,they are coming.
If you like drag racing, support your local track.
[Re: CHAPPER]
#1565094
01/19/14 11:57 AM
01/19/14 11:57 AM
MattW
Ontario Canada
Some dirt track forum has a thread about the LS Oiling issues. It refers to RPM. Seems they have the same problem as the G3. Matt
[Re: Skeptic]
#1565096
01/19/14 04:09 PM
01/19/14 04:09 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I think I heard them say on horse power tv this morning that Harland Sharp is making rocker arms for the Gen 3 hemi. Is this new or have they been out for a while?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1565097
01/19/14 05:03 PM
01/19/14 05:03 PM
Posts: 12,415 Taxes & Virus's R-US, NY
Dragula
They made them 4 years ago, and I have yet to see a set. Rumor is they were about $2k for a set....This whole Gen3 Hemi is really expensive. From the stroker kits to the ignition, to the valve train. More and more, I can build a big inch stump puller for a lot less. Notice the crappy hold downs too. The SDC ones are way better. Steff did it right..
[Re: Dragula]
#1565098
01/19/14 05:32 PM
01/19/14 05:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The geometry looks all wrong with the SDC rockers... looks up way to high ... but since I havent measured it I dont know for fact
[Re: MR_P_BODY]
#1565099
01/19/14 05:45 PM
01/19/14 05:45 PM
Posts: 27 indiana
flatfoot
indiana
i'd be more likely to put a mopar in a gm body.a 2nd gen camaro, or a g body.i don't like gm, but do like those body styles.and you can pick one up cheap, not all rusted out(like an a body), and make a fast drag car out of one.i'd rather have a 318 in a gm body than a ls in any mopar.but hey, that's me.i'm at the point where i have respect for any fast car, regardless of brand.but when it comes to building one, mine will be mopar powered, regardless of body style.and as mentioned, the money issue.i'd love to have a 358 cube former nascar engine with a manual trans, but it's the $$ issue holding me back.so i'm forced to use magnum 5.2 with a turbo, and home brew up a system.i'm not afraid of trying something new(turbo, or nitrous), and i'd love to have a hemi, but $$ again.to each his own.and i remember a mopar powered camaro from years ago who did quite well.
[Re: Dragula]
#1565100
01/19/14 05:53 PM
01/19/14 05:53 PM
Posts: 5,166 CT
GTX MATT
CT
No offense to the guys saying this because I understand your point, but to compare the disparity between the LS and Gen III Hemi engines vs B/RB engines (and any other popular performance engine from the musclecar era) to the disparity between the 60s performance engines and the flatheads is just plain stupid.
WOW, LS guys have heads that flow 400 cfm? So do we, why don't you go buy a pair and bolt them on? A company called Brodix makes them, maybe you've heard of them? Too expensive? Edelbrock makes a nice cheap head that can get there too with some serious work. And theres another company called Indy that makes good heads for us.
They have aftermarket blocks? Those bastards! But so do we. And the blocks that they have look more expensive than ours. Sorry guys, this is turning into a thread of guys who sit around and gripe about how good the LS engines are and how we get no support from the aftermarket. Maybe we don't have it the best but it's not that bad and its the best its ever been. They do it on the mustang forums too, I swear there are Ford guys who believe that the 98-02 F body LS1 cars ran 12.80s stock. Why even turn this into an LS1 vs Gen 3 Hemi deal when we can make very good power with a B/RB engine. Thats hardly a Flathead Ford complex.
[Re: Dragula]
#1565102
01/19/14 09:09 PM
01/19/14 09:09 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
When I had my Dart at the track the tech guy though my Gen3 Hemi was a LS motor!
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: GTX MATT]
#1565103
01/19/14 09:21 PM
01/19/14 09:21 PM
72Swinger
Nebraska
nobody said BB mopes don't make power, can a BB make 650hp with stock rockers,lifters, OEM head castings,OEM intake and run great on pump gas? Can it do it without a distributor? Haha nope......
[Re: Streetwize]
#1565104
01/19/14 10:39 PM
01/19/14 10:39 PM
Posts: 793 Utah
topbrent
Utah
Ignorance isn't a virtue. Plenty of ignorance to go around on both sides of the table. New tech vs legacy old school brand loyal. While nobody likes to have some jerk tell them their stuff is archaic and doesn't work, there are plenty of traditionalists in the Mopar world that just have their heads stuffed in the sand or elsewhere. The traditionalists are every bit as ignorant and rude when the topic arises. Hotrodding is expensive. Engine swaps are part of hotrodding. Don't be angry about innovation. Moreover, in this economic day and age, be happy to see any old car get running regardless of the powerplant. More and more formerly vintage only guys are choosing to just abandon their old non-operational relic in the garage to just buy a new/used Challenger, Camaro, or Mustang. The the price of entry for these cars is now no longer out of the financial reach for most people. 18K buys a heck of nice hot rod these days. Though not a popular sentiment around these parts, the LS platform is great and it would be fun to have the swap friendly mentality, parts and tools for our benefit here in the Mopar realm. (IMHO) There can/should be room enough for them in the Mopar world. - The Dana 60 is stronger than the Mopar 8-3/4. - Dodge trucks pull better with Cummins diesels. - P-51 Mustangs flew better once the Rolls Royce Merlin replaced the Allison V12. - The Colt M4 is a more useful weapon than a blunderbust. - Mopar installs PowerGlide's and 9" Ford rears in their factory race Challengers. Install the engine of your choice, traditional or modern, as it is a great era to build horsepower whatever your choice may be.
[Re: 72Swinger]
#1565105
01/20/14 01:26 AM
01/20/14 01:26 AM
Posts: 5,166 CT
GTX MATT
CT
I haven't seen many 650 hp LS engines with stock intakes, rockers, lifters, and untouched heads. Unless you're talking about doing this with an LS7, in which case at that kind of price: Hemi. They're pretty tricked out when they're making that kind of power, just like any engine. The point is you can go as fast or faster, its in no way comparable to a flat head Ford.
[Re: GTX MATT]
#1565107
01/20/14 08:05 AM
01/20/14 08:05 AM
72Swinger
Nebraska
I wasn't using an LS as a comparison, I was talking Gen III Hemi. Honestly the LS has nothing on a Gen III when it comes to making hp N/A with factory parts. An LS can HANDLE more power under boost with factory parts. When you can get in the 365cfm at .600 lift range with stock valves and a $700 port job what's not to like? Gen III Hemis are a jewel that we need to embrace.
[Re: 72Swinger]
#1565108
01/20/14 04:53 PM
01/20/14 04:53 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Some of you guys need to go price this stuff. An ls 7 is about 13000 for just the engine, an Ls3 or 6.2 is about 9000, just the engine. Chrysler sells the 6.1 for 9000 with everything you need to make it run except the fuel pump. I think you can buy just the 6.1 for around 7500. Mopar looks cheaper to me if you start with new stuff.
[Re: 4406bbl]
#1565109
01/21/14 07:32 AM
01/21/14 07:32 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
This is what has me Turned off with Junk Yards as well. $6000+ for a 6.1l Hemi that has 20-60K miles and no computer or accessories. Hello spend an extra grand or 2 and get all NEW with Computer and Accessories from Ma Mopar.
On the flip side the 5.7l Hemis are pretty affordable from the scrappers. Just talked to someone last week that Bought 2 for $1200 total. One had 12,000 miles and the other about 80,000 miles. Included all accessories.
That would be the way to go if you know your going to go through it and build it YOUR WAY.
Unfortunately from what I am hearing the Hemi Blocks and Heads NEW are (if not already) drying up fast with NO Intentions of supplying more by Mopar. If this is true? and you want NEW better break out the Benjamins, for an Aluminum Block. $4500+ last I checked.
