Cast iron headers for max wedge heads #1564948
01/18/14 02:50 AM
01/18/14 02:50 AM
Lake Charles, LA
calexan Offline OP
calexan  Offline OP
Lake Charles, LA
Can i put cast iron headers made for max wedge heads on my regular big block heads?
Re: Cast iron headers for max wedge heads [Re: calexan] #1564949
01/18/14 03:18 AM
01/18/14 03:18 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Yes. Might have clearance problems in a later car, though.
Re: Cast iron headers for max wedge heads [Re: calexan] #1564950
01/18/14 03:18 AM
01/18/14 03:18 AM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
Sure can,my oldest brother used to do it on his 64 Fury back in the day. It was just a 383, but the MW exhaust system was way better than the factory log manifolds.
Re: Cast iron headers for max wedge heads [Re: Goat330] #1564951
01/18/14 06:52 AM
01/18/14 06:52 AM
smyrna,tn
draginmopars Offline
smyrna,tn
a tall valve cover will hit on the passengers side
this was pieces / parts for a rat rod- car hauler build, later went to a cummins/5 speed
on a 68 satellite the master cylinder had to be moved (toward the outside) 2 "
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Cast iron headers for max wedge heads [Re: draginmopars] #1564952
01/18/14 07:41 AM
01/18/14 07:41 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
you cant run power brakes.
I am truckless..
Re: Cast iron headers for max wedge heads [Re: 340SHORTY] #1564953
01/18/14 12:02 PM
01/18/14 12:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, you can. He's obviously not building a stock setup so that opens up many options.
Don't be the exception.
Re: Cast iron headers for max wedge heads [Re: Supercuda] #1564954
01/19/14 01:24 AM
01/19/14 01:24 AM
Lake Charles, LA
calexan Offline OP
calexan  Offline OP
Lake Charles, LA
thanks for the replies. i'm going to put them on a 440 in a Plymouth Sport Fury. i haven't seen the car yet but if it power brakes, i can convert. Charles
Re: Cast iron headers for max wedge heads [Re: calexan] #1564955
01/19/14 06:21 AM
01/19/14 06:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They are cool for the Max Wedge look but they are heavy and hold heat longer then headers. I was going to use them but decided it was easier to just use headers and the headers make a bit more power. Ron
