Re: Got my header collector cables today - $59.00 delivered
[Re: MoParFish]
#1563840
01/16/14 06:27 AM
01/16/14 06:27 AM
Posts: 345 iowa
wesw
iowa
thanks for the info. going to order some Friday for my car.
598 ci predator
[Re: wesw]
#1563841
01/16/14 07:14 AM
01/16/14 07:14 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Those are the ones I ordered.. Best price.. Don't need anything fancy because I STILL have my bolts in too.. Was going to weld the stitch, but my headers are coated.. Also Jok Nicholson is a good dude.. Chris..
[Re: dvw]
#1563843
01/17/14 02:22 AM
01/17/14 02:22 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
They should require them for hoods, I have seen a few collectors come off over the years but I have also seen a lot more hoods fly up in the air. But then if they can't remember to put in the hood pins they wouldn't attach the cable either.
[Re: rowin4]
#1563844
01/17/14 03:08 AM
01/17/14 03:08 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Well if you want to play in their playground they get to make the rules. It is what it is bit#h all ya want.
[Re: THE GLASS MAN]
#1563846
01/17/14 11:55 AM
01/17/14 11:55 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
On my car there are tabs welded to the 2" header tubes and tabs welded to my collectors. They have holes to be able to secure the 2 together. With the bolt and nut tight, why do you have to spend money on tethers? Sounds political to me.
You don't...... if you weld them!
[Re: Al_Alguire]
#1563848
01/17/14 10:34 PM
01/17/14 10:34 PM
Posts: 9,840 MI, usa
dvw
MI, usa
I agree with you 100%. It's just getting harder and harder for the average guy to afford to race. My stuff is and will be 100% legal. Anything can fall off the car if it's loose. I've seen more hoods, wheels and doors come off than collectors. That was my point. A new cert every 3 years? Did my car rust out? New belts every 2 years that haven't seen 60 days of sun shine? Yet when I show up at the track most times they don't even care if I remove the hood, heaven forbid they bend over and look underneath the car. Just my 2 cents. I'll have my teathers as you can't remove my headers w/o taking the collectors off. Doug
[Re: Adrielp]
#1563850
01/18/14 02:56 PM
01/18/14 02:56 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Some years ago there was a horrible accident at the Phoenix race with Antron Brown's fuel dragster when it lost a wheel at the starting line and flung it into the stands. A spectator was killed. Anyone besides me remember that? How do you put a tether on a wheel?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: MoParFish]
#1563853
01/19/14 02:32 PM
01/19/14 02:32 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Header Tether Requirement Clarification http://www.nhraracer.com/content/gen...836&zoneid=132For the 2014 season and beyond, NHRA has made the following requirement: All removable multipiece exhaust collectors/stacks must be securely fastened with either an NHRA-accepted header tether or a minimum ½” (half-inch) stitch weld located on each primary tube to prevent loss of collector/stacks during competition. After much discussion on the topic, it has been decided that on cars with a complete exhaust system (including but not limited to mufflers, hangers, flanges, etc.) that are securely attached to the vehicle, header tethers will not be required. All other exhaust systems must conform to the rule as written. The current 2014 rulebook will be amended to reflect this change. HisPony is offline Report Post Reply With Quote
[Re: pittsburghracer]
#1563855
01/20/14 11:31 PM
01/20/14 11:31 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Question...my collectors on my TTi headers are welded on...but I bolt on a 1 ft extension...does the extension need a tether?,,,,...
and do i need a tether to hold the headers on, since they are bolt on too?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
