Re: It's a funny squeaky noise!
[Re: stumpy]
#1563244
01/14/14 08:16 PM
01/14/14 08:16 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
did that once, wasn't a funny squeek, it destroyed the rotor on my gfs car.
1981 Dodge D150 360 auto
[Re: stumpy]
#1563245
01/14/14 08:34 PM
01/14/14 08:34 PM
Posts: 5,327 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Thanks Stumpy, but everything was double checked before it was buttoned up, pads are all on correctly. I called a local shop, and they mentioned that the axle shaft itself may be out of round...anyone here ever hear of this...causing a squeaking noise??
[Re: RoadRunnerLuva]
#1563246
01/14/14 10:11 PM
01/14/14 10:11 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Check your u joints and wheel bearings. I have had a dry ujoint be the culprit to a squeak. Jack it up and put it on jack stands. Block the front wheels, and have a friend put it in drive....just my 5 cents worth. Could be a sticky caliper too. You could check that while you have it up in the air. ok, my 8 cents worth, haha!
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: Fat_Mike]
#1563249
01/17/14 12:36 AM
01/17/14 12:36 AM
Posts: 233 vashon island washington
hunterstroble
Often times the aftermarket pad slides, clips, ect will rub the rotor because the are not quite right. I always reuse the factory shims and stuff.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
