head gasket suggestions #1562970
01/13/14 11:37 PM
01/13/14 11:37 PM
USA
74DS Offline OP
74DS  Offline OP
USA
Hi ! Any suggestions for head gaskets ; 340 .030
stroked to 416 , with edelbrock heads compression about 10.9:1 ?
Thanks in advance !!!
Re: head gasket suggestions [Re: 74DS] #1562971
01/14/14 12:08 AM
01/14/14 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have that same set up and I have been using the
Felpro with zero problems
EDIT
Different heads but the same compression
Re: head gasket suggestions [Re: 74DS] #1562972
01/14/14 12:12 AM
01/14/14 12:12 AM
BPE Offline
BPE  Offline
Felpro 1008
Rod
Re: head gasket suggestions [Re: 74DS] #1562973
01/14/14 03:35 AM
01/14/14 03:35 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Cometic C5622-040. In stock at Summit
Re: head gasket suggestions [Re: BPE] #1562974
01/14/14 05:55 AM
01/14/14 05:55 AM
Cab_Burge Online work
Cab_Burge  Online Work
Felpro 1008
Rod
I have used them on several NHRA legal 340 stocker motors that made over 430 HP, they blueprint out to have 11.4 to 1 compression ratio and still be legal
Re: head gasket suggestions [Re: Cab_Burge] #1562975
01/14/14 08:20 PM
01/14/14 08:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Felpro 1008
Rod
I ran the 1008 at 12.5-1 with no problems at all.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
