How to remove spray paint from alum. slot wheels? #1562716
01/13/14 02:46 PM
01/13/14 02:46 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I just picked up a set of 15 inch Aluminum slots from the local u pull r parts for scrap price. They are in good shape except someone had spray painted them black at one point. Now how can I remove the spray paint with out damaging the face of the wheel?
Thanks for any help
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: How to remove spray paint from alum. slot wheels? [Re: TX9H6E4CUDA] #1562717
01/13/14 02:56 PM
01/13/14 02:56 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've had them sandblasted a bunch of times in the past, no problems.
(I usually have them polished afterwards..)
Re: How to remove spray paint from alum. slot wheels? [Re: TX9H6E4CUDA] #1562718
01/13/14 03:08 PM
01/13/14 03:08 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
Thanks for any help
try soda blasting
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: How to remove spray paint from alum. slot wheels? [Re: azmopar] #1562719
01/13/14 03:21 PM
01/13/14 03:21 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Thanks for any help
try soda blasting
Shaking a Dr. Pepper and opening it over the wheels?
Re: How to remove spray paint from alum. slot wheels? [Re: OzHemi] #1562720
01/13/14 03:55 PM
01/13/14 03:55 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
Thanks for any help
try soda blasting
lol no
#NONIKESEVER
Re: How to remove spray paint from alum. slot wheels? [Re: TX9H6E4CUDA] #1562721
01/13/14 04:16 PM
01/13/14 04:16 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Heated pressure washer will remove the paint without hurting the wheels or the finish under the paint in most cases.
Re: How to remove spray paint from alum. slot wheels? [Re: TX9H6E4CUDA] #1562722
01/13/14 05:23 PM
01/13/14 05:23 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My guess would be they are already sanded or blasted under the paint. I'd buy a spray can of paint stripper and let it lift then pressure wash them.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: How to remove spray paint from alum. slot wheels? [Re: Silver70] #1562723
01/13/14 09:27 PM
01/13/14 09:27 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
The paint stripper can damage the aluminum. I wouldn't use it. Try lacquer thinner on a rag instead.
Re: How to remove spray paint from alum. slot wheels? [Re: Powerflow] #1562724
01/13/14 10:15 PM
01/13/14 10:15 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
brake fluid
I am truckless..
Re: How to remove spray paint from alum. slot wheels? [Re: 340SHORTY] #1562725
01/13/14 10:43 PM
01/13/14 10:43 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
brake fluid
and prob wont hurt the alum finish
#NONIKESEVER
Re: How to remove spray paint from alum. slot wheels? [Re: 340SHORTY] #1562726
01/13/14 10:56 PM
01/13/14 10:56 PM
MN
astrobuf Offline
astrobuf  Offline
MN
brake fluid
Most likely this was painted with a rattle can. Either lacquer thinner or brake fluid and elbow grease should do it without damaging the original clear powder coat.
Astrobuf
Re: How to remove spray paint from alum. slot wheels? [Re: 340SHORTY] #1562727
01/13/14 11:04 PM
01/13/14 11:04 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
brake fluid
x2
Bought a set of weld wheels pained black and brake fluid removed the paint no problem.
Re: How to remove spray paint from alum. slot wheels? [Re: moparpollack] #1562728
01/14/14 02:13 AM
01/14/14 02:13 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I agree. soak some paper towels in BF and lay them on the wheels, then bag them in plastic. Let 'em sit a few days, then hose off.
Re: How to remove spray paint from alum. slot wheels? [Re: RodStRace] #1562729
01/14/14 03:45 AM
01/14/14 03:45 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Another vote for laquer thinner. Should take care of it in short order. brake fluid is nasty stuff. I don't even like using it on brakes!
I’m listening.
