Big tire mockup on a '59 Dodge... #1562353
01/12/14 09:57 PM
01/12/14 09:57 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
This is a 375/60/15 ProTrac tire.
With a spring relocation and remodelling of the wheelwell it would fit perfectly between the outer fender and the framerail...
Here however is a 325/60/15 MT tire, which would fit inside the stock wheelwell and 'maybe' with the stock springlocation aswell, but I'm not quite sure about that yet.
I think it does look good though...
Both tires mocked up...
Re: Big tire mockup on a '59 Dodge... [Re: BigBlockMopar] #1562354
01/12/14 10:31 PM
01/12/14 10:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
So, what happens when you get some body roll?
Or sidewall flex?
I ask because the N50's I had on my 64 300 fit fine, till the above happened then they would just kiss the leafs.
Don't be the exception.
Re: Big tire mockup on a '59 Dodge... [Re: Supercuda] #1562355
01/12/14 11:36 PM
01/12/14 11:36 PM
moparx Offline
moparx  Offline
a ? for both. how much sidewall to spring/fender did you have ? i like to see about 3/4" minimum if possible.
Re: Big tire mockup on a '59 Dodge... [Re: moparx] #1562356
01/12/14 11:48 PM
01/12/14 11:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
In my case I forget how much clearance I had, I sold that car almost 20 years ago. Didn't have an issue out the outside, just the inside of the tire and it kissed just enough to rub a shiny spot on the leaf spring edge. But I doubt it was 3/4" clearance on the inside.
Re: Big tire mockup on a '59 Dodge... [Re: moparx] #1562357
01/13/14 06:22 AM
01/13/14 06:22 AM
The Netherlands
The Netherlands
On the Dodge I will be moving the leafsprings to the inside of the frame rails.
From what I've seen in the mockup yesterday I believe there's about an inch of room between frame rail and outer fender.
I do have to remake the entire wheelwell and make the inner part flush with the frame in order to be able to install the large 375 tires.
Re: Big tire mockup on a '59 Dodge... [Re: BigBlockMopar] #1562358
01/17/14 04:58 AM
01/17/14 04:58 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
love this project,those cars have a beautiful rooof line,,love the fat tires,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Big tire mockup on a '59 Dodge... [Re: fstfish66] #1562359
01/17/14 08:46 AM
01/17/14 08:46 AM
The Netherlands
The Netherlands
The roofline indeed is cool.
My plans however are to turn it into a 'removable' hardtop.
With a winch in the garage I plan to be able to lift the entire roof, install a 'convertible-like' cover and take it for a sunny spin.
The roof will be locked into place on the body with heavyduty clamps and pins.
Even though the car has a full chassis frame, the car/body itself will be reinforced in various places to counter deformation.
Re: Big tire mockup on a '59 Dodge... [Re: BigBlockMopar] #1562360
01/17/14 04:54 PM
01/17/14 04:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of a '59 that I started but lost interest in, it was finished by a friend. It has 29 X 12 Mickeys on the rear, springs were moved onto the frame and it's tubbed.
Re: Big tire mockup on a '59 Dodge... [Re: BigBlockMopar] #1562361
01/17/14 05:34 PM
01/17/14 05:34 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
sounds kool good luck
2015 cherokee
2013 R/T classic
Re: Big tire mockup on a '59 Dodge... [Re: John_Kunkel] #1562362
01/17/14 05:39 PM
01/17/14 05:39 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
very kool,glad some one finished it
2015 cherokee
2013 R/T classic
Re: Big tire mockup on a '59 Dodge... [Re: John_Kunkel] #1562363
01/17/14 07:07 PM
01/17/14 07:07 PM
The Netherlands
The Netherlands
Thanks for that pic John.
Eventhough I'm not a real ProStreet-follower, that is, for this car, just about the 'tire-look' I'm after.
I will also need to lift the driveshaft tunnel so the body can drop low enough over the rearaxle.
