Do the newer Jeep speedo gears work in the A833s? #1561710
01/11/14 02:30 AM
01/11/14 02:30 AM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
I get conflicting info on this because people seem to know one vehicle type or the other. But someone somewhere told me the Mopar speedo gears were the same for many years. Anyway, can someone tell me if this 38 tooth Jeep speedo gear on Ebay will work in my 4 speed 68 Charger?
http://m.ebay.com/itm/281119932256?nav=SEARCH&sbk=1
1968 Charger 383/2bbl/4spd (1 of 74) 1994 Dakota Sport 3.9L/AT/2WD 2003 Durango SLT 4.7L/AT/4X4 Yes, all Dodges and nothing else
Re: Do the newer Jeep speedo gears work in the A833s? [Re: bull] #1561711
01/11/14 02:55 PM
01/11/14 02:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If that picture is the actual part .. I would say yes without actually having it in my hand.
this one is cheaper
http://www.ebay.com/itm/Dodge-Jeep-38-To...281119932256%26
Re: Do the newer Jeep speedo gears work in the A833s? [Re: bull] #1561712
01/11/14 05:00 PM
01/11/14 05:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The long-shaft pinion pictured is correct for a '68, hopefully the seller isn't using a generic pic and the item is actually a long-shaft pinion.
A 38 would be blue and the current P/N is 52068060.
Re: Do the newer Jeep speedo gears work in the A833s? [Re: John_Kunkel] #1561713
01/12/14 01:20 AM
01/12/14 01:20 AM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
Rather than ask if it's the actual pic I asked specifically if it will fit a 1968 Charger A833. We'll see where that gets me.
Re: Do the newer Jeep speedo gears work in the A833s? [Re: bull] #1561714
01/12/14 11:04 PM
01/12/14 11:04 PM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
Here's my question: I have done some checking on this but please verify. Near as I can tell this gear should work in my 68 four speed Charger. But as mentioned there could be some cable trimming involved. Does that sound correcf?
And here's his answer: That is correct, its likely you will have to but thats not always the case, just look when you install it.
Re: Do the newer Jeep speedo gears work in the A833s? [Re: bull] #1561715
01/13/14 03:28 AM
01/13/14 03:28 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Who would want to cut their speedometer cable? not me...
Re: Do the newer Jeep speedo gears work in the A833s? [Re: Mr_fixit] #1561716
01/13/14 03:36 AM
01/13/14 03:36 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Interesting. Let us know if you do it and it works. Maybe I'll go to PicNPull one day and see if there's a Jeep there to pull one out of. Minor mods would be no big deal.
Sheldon
Re: Do the newer Jeep speedo gears work in the A833s? [Re: bull] #1561717
01/13/14 12:52 PM
01/13/14 12:52 PM
scratchnfotraction Offline
I just swaped a short pinion gear and housing to a long pinion/housing on my nv4500 to hook up the 85 speedo cable.
that long one should go right into the stock 4 speed housing. make sure it is clocked correctly when installed.
un-less seller has the wrong pic it is good.
Re: Do the newer Jeep speedo gears work in the A833s? [Re: scratchnfotraction] #1561718
01/15/14 11:45 PM
01/15/14 11:45 PM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
I'll report the resulrs as soon as I can. Thanks for the help.
