summit 204/214 cam bad choice for 273 ?? #1561696
01/11/14 12:53 AM
01/11/14 12:53 AM
Ohio
rustytoolss Offline OP
Ohio
I'm rebuilding my 273 +.030, Flat top pistons, 302 heads, Eddy performer intake, 600 cfm, 727 low stall, 3.23, exh maniflds & flow masters, 3000 lbs. 8.5 compression.
Looking for a cam, for a DD. would like to improve lowend TQ, Mileage.
Was looking at summits K6900 204/214 @.050 .421/.444 LSA 112. I rarely drive over 4500 rpm, ( getting old I guess ) would this cam be OVER kill for a small cylinder 273 ?
What would you look for to get lowend & mileage ??
Re: summit 204/214 cam bad choice for 273 ?? [Re: rustytoolss] #1561697
01/11/14 02:13 AM
01/11/14 02:13 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I got a 273 4 speed 3.23 TTI's B body in the projects forum. What size valves? I would like to see more CR. Mine has a mild Comp Cam. I think it runs great for what it is, lousy mileage though, but thats the carb tune I believe. I think your cam is a little tame. I'll try and find my Cam card FWIW.
Re: summit 204/214 cam bad choice for 273 ?? [Re: jcc] #1561698
01/11/14 02:19 AM
01/11/14 02:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
No matter what cam you go with you will gain HP by getting rid of the floers ..
I am truckless..
Re: summit 204/214 cam bad choice for 273 ?? [Re: jcc] #1561699
01/11/14 02:26 AM
01/11/14 02:26 AM
Ohio
Ohio
Budget build, stock valves. Also rear tires are 29". I just dint wnt to do the " over cammed it thing"
Re: summit 204/214 cam bad choice for 273 ?? [Re: 340SHORTY] #1561700
01/11/14 02:28 AM
01/11/14 02:28 AM
Ohio
Ohio
I don't care for them myself. Were on it when I bought it
Re: summit 204/214 cam bad choice for 273 ?? [Re: rustytoolss] #1561701
01/11/14 11:22 AM
01/11/14 11:22 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I understand and agree, I looked last night and couldn't locate my cam card from previous owner, I'll keep looking. But bumping the CR is free HP/efficiency and it helps in taking the edge off a slightly hotter cam, but being reasonable on cr keeps 87 gas a solution. If mileage is the major concern, just adding ANY tube headers is best single improvement bang for buck for mileage increase, IMO.
Re: summit 204/214 cam bad choice for 273 ?? [Re: jcc] #1561702
01/11/14 04:13 PM
01/11/14 04:13 PM
Ohio
Ohio
Yeah headers would help. But I don't want to deal with leaks, and the heat under to hood . I've got an A100 with the engine between the seats. From what I've read I need a short duration/ high lift cam. But what di I know ?
Re: summit 204/214 cam bad choice for 273 ?? [Re: rustytoolss] #1561703
01/11/14 06:10 PM
01/11/14 06:10 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Generally speaking, for what you're doing a shorter-duration cam would be best. 8.5 CR is maybe a bit low, but the 204/214 won't be a problem, and might allow lower (cheaper) octane. Me, I'd like to see lift with that combo in the .450-.470 range to pick up the power without any ill side-effects. Some 1.6 rockers would be nice to find. But I'd have no problem sticking that cam in there with your combo.
Re: summit 204/214 cam bad choice for 273 ?? [Re: topside] #1561704
01/11/14 06:37 PM
01/11/14 06:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think the larger summit cam might work better...
Coming soon!!!!
Re: summit 204/214 cam bad choice for 273 ?? [Re: rustytoolss] #1561705
01/11/14 07:08 PM
01/11/14 07:08 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Sounds just like this cam
http://www.ebay.com/itm/Dodge-318-340-36...373&vxp=mtr
These are hydraulic cams. If you have a pre '67 engine, you will probably have solids. The Elgin cams are great cams at a reasonable cost. A well kept secret.
This is the land of the free because of the brave
Re: summit 204/214 cam bad choice for 273 ?? [Re: rbstroker] #1561706
01/11/14 09:40 PM
01/11/14 09:40 PM
Ohio
Ohio
At some point in its life, was changed over to hydraulic valve train.
