1972 challenger gas tank vents #1561592
01/10/14 07:55 PM
01/10/14 07:55 PM
GA
Shoet1 Offline OP
Shoet1  Offline OP
GA
I have a 72 challenger gas tank with four vent tubes coming out of the front of it. My question is can I cap all four off or just jumper them together. Or does the tank need to vent, I will not be putting the can back in the engine compartment.
Thoughts?
Re: 1972 challenger gas tank vents [Re: Shoet1] #1561593
01/10/14 09:48 PM
01/10/14 09:48 PM
IN
ahy Offline
ahy  Offline
IN
If the canister is intact it makes a really good vent system. I just ran what had been the engine vent inside the left frame rail and it works great. In the rail is good in the unlikely event liquid comes out, it will run out slowly.
If you plug it you will need another vent system... and vented caps don't work so well in my experience.
Re: 1972 challenger gas tank vents [Re: Shoet1] #1561594
01/10/14 10:34 PM
01/10/14 10:34 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Put it back exactly the way it was stock in the back. It's the only way your tank will vent properly and not stink up your garage.
Run all four vent lines to the vapor separator in the rear and one line runs from it to the front engine compartment and should be terminated at least as high as the valve cover top or the top of the intake manifold. Then it ran to the charcoal canister on 73-74 cars.
I suggest you vent it to the breather(3 nipple) or the inside of the air cleaner because it don't sound like your concerned with originality.
71 it ran to the breather(3 nipple) on the passenger valve cover and in 73-74 it ran to the top of the intake manifold and then to the charcoal can.
In 72 I'm not sure, but either way I mentioned would work the best and be 100%.
Do it right and don't cut corners on the gas tank venting. You'll be sorry if you do.
Re: 1972 challenger gas tank vents [Re: Challenger 1] #1561595
01/10/14 11:47 PM
01/10/14 11:47 PM
GA
Shoet1 Offline OP
Shoet1  Offline OP
GA
Thanks for the input, I will run it as it was. I have all the original parts, but the engine is trashed and we were going to resto mod it a little. But if that's the best way to go I will.
Re: 1972 challenger gas tank vents [Re: Shoet1] #1561596
01/11/14 01:29 AM
01/11/14 01:29 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Excellent advice Gary!
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
