main hoop angle #1561137
01/09/14 03:30 PM
01/09/14 03:30 PM
illinois usa
K
king coronet Offline OP
K
illinois usa
when putting a rollcage in do you angle the main hoop back? thanks
Re: main hoop angle [Re: king coronet] #1561138
01/09/14 03:43 PM
01/09/14 03:43 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I do. I like them to astheticly follow the b pillar. I also find it to give me a little more room being a taller driver. Still gives better rear seat room too.
Re: main hoop angle [Re: dizuster] #1561139
01/09/14 08:08 PM
01/09/14 08:08 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: main hoop angle [Re: king coronet] #1561140
01/09/14 10:53 PM
01/09/14 10:53 PM
If your installing the roll bar for racing you need to look at the rules for that installation for you in the car what may be legal for you in your car may not be legal with me in your car Don't be disappointed , build it for you to fit the rules
Re: main hoop angle [Re: Cab_Burge] #1561141
01/10/14 03:05 AM
01/10/14 03:05 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
B pillar or right behind the front door jamb. I hate seeing roll bars in the side window. Not to mention what was already said, put it back for some room, if your short move the column and the pedals back. The Farther back the main hoop is the more room to get in and out over the side bar(s).
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: main hoop angle [Re: bigtimeauto] #1561142
01/10/14 09:15 AM
01/10/14 09:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I moved mine back and it follows the B-Pillar. I asked our division 3 tech director about it, no issue. Mine was certed by him also.
Doug
Re: main hoop angle [Re: dvw] #1561143
01/10/14 11:04 AM
01/10/14 11:04 AM
west palm beach, florida
modelmakerinc Offline
Mine is vertical, but set back as far as possible on a square tube outrigger. It hides nicely behind the B-pillar.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: main hoop angle [Re: modelmakerinc] #1561144
01/10/14 11:32 AM
01/10/14 11:32 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
When I had my Challenger re-caged, I wanted the main hoop further back in the car than it was previously, which would have meant adding something behind the main ladder bar cross member as the anchor point. The builder talked me into simply angling it back instead. It worked great, gave me the leg room I coveted, and easy access for a 300 pound man even with a funny car cage.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: main hoop angle [Re: king coronet] #1561145
01/10/14 12:11 PM
01/10/14 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its a full cage car I like to have the customer
sit in the car on the seat and set the angle of the seat
to get it right(front of the seat supporting the knee)
and far enough that he can hit the firewall with his feet
and then determain where the hoop needs to be and
if it needs to be angled... I tend to play with small
cars so in most cases the bar is behind the B-pillar...
the hoop can be angled alot farther than most would
think and still pass tech... I put Scotts bar in his
car and we ran his seat all the way back to see where
it would need to be and the angle
Re: main hoop angle [Re: Cab_Burge] #1561146
01/10/14 12:20 PM
01/10/14 12:20 PM
Az
Crizila Offline
Crizila  Offline
Az
Good advice.
Fastest 300
Re: main hoop angle [Re: king coronet] #1561147
01/10/14 11:59 PM
01/10/14 11:59 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
There is no rule for angle other than the driver must be within the confines of the roll bar or cage, I always lay them back 15 degrees.
Re: main hoop angle [Re: loaderpro] #1561148
01/11/14 03:42 AM
01/11/14 03:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On mine I just put it level as I did not pay much attention to lining it up with my front to rear side window post. Ah well no one's ever complained. Ron
