Does Anyone Make Sway Bar Tabs For Controll Arms? #1560696
01/08/14 07:09 AM
01/08/14 07:09 AM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
Does anyone out there make sway bar tabs for welding onto 73-76 A-Body lower control arms? I have access to a metal shop and could probably fab up a set but if someone already makes them it would save me some time.
Do not hug a man holding a wrench in his hand.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Bones] #1560697
01/08/14 11:27 AM
01/08/14 11:27 AM
Andrewh Offline
Andrewh  Offline
hotchkis and firm feel I think both make them.
another company makes one that mounts to the shock bolt instead of having to weld as well, but I can't remember who that is.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Andrewh] #1560698
01/08/14 02:24 PM
01/08/14 02:24 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
Hmm.. very curious about this
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: cal_gecko] #1560699
01/08/14 04:16 PM
01/08/14 04:16 PM
Andrewh Offline
Andrewh  Offline
helwig maybe.
summit has instructions that show it.
http://static.summitracing.com/global/images/instructions/sum-720230.pdf
but not sure what bar.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Andrewh] #1560700
01/08/14 05:15 PM
01/08/14 05:15 PM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
I see them sold as part of their front sway bar set but don't see them sold on their own. Can anyone direct me to a set sold on their own without the kit?
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Bones] #1560701
01/08/14 06:22 PM
01/08/14 06:22 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Hotchkis sells them seperatly. Go to their website. And they a thicker than stock too.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: autoxcuda] #1560702
01/08/14 08:59 PM
01/08/14 08:59 PM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
Thanks a lot.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Andrewh] #1560703
01/08/14 09:43 PM
01/08/14 09:43 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Hellwig bar for my 68 Charger came with the tabs that bolt to the lower shock bolt
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: autoxcuda] #1560704
01/09/14 01:53 PM
01/09/14 01:53 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
That would have been nice to know after i welded one of them on upside down
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: VoodooCLD] #1560705
01/09/14 02:04 PM
01/09/14 02:04 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..cut 2 1/2" of square tubing on the diagonal and you'll have 2
detail with a file/drill
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: autoxcuda] #1560706
01/10/14 06:36 PM
01/10/14 06:36 PM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
I called the Hotchkis sales department and was told that they are not usually sold separately. The guy took my email info and said he would talk to his manager about putting them in the computer so he could sell me a pair separately from the sway bar kit. Hopefully he will get back to me.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Bones] #1560707
01/10/14 07:02 PM
01/10/14 07:02 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
I'm pretty sure i ordered mine separate from my sway bar kit. Only problem was they only sold them in pairs. So i ended up buying a whole other set when i welded one upside down.
I don't think building a car is expensive, building it twice due to my own stupidity is expensive
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Bones] #1560708
01/10/14 07:06 PM
01/10/14 07:06 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Bones:
I haven't a clue why your having such a heartburn in getting sway bar mount tabs direct from Hotchkis.
You asked me that question over on ebay, through the "ask the seller a question" in regards to the rebilt lower control arms that i rebuild, then resell.
I told you that i get tabs from Hotchkis direct.
Summit sells them, along with numerous other automotive warehouses, that sell Hotchkis products.
What you want is #233367
They are $45.00 a pair, from Hotchkis themselves.
I have bought lots of them for my LCA rebuilding.
Jim V.
hemi71x
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Bones] #1560709
01/10/14 07:09 PM
01/10/14 07:09 PM
Houston, Texas
Slant6pak Offline
Slant6pak  Offline
Houston, Texas
???? They are listed on the website... they are just a royal PITA to find. Google search "hotchkis sway bar bracket" and you will find them for sale from several different places.
Hotchkis makes good stuff, but my experience with them is that the answer to every question you have about suspension on Mopars is: "buy our entire kit".
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: hemi71x] #1560710
01/10/14 09:38 PM
01/10/14 09:38 PM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
Thanks a bunch for the info hemi71x, I really appreciate it. I'll check Summit and do another google search. I've done several searches but was using the word "tabs" instead of "brackets" which is what Hotchkis calls them. And thanks for not getting upset when I asked you a Q on ebay without reading your text thoroughly.
Bones:
Jim V.
hemi71x
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: Bones] #1560711
01/11/14 01:43 AM
01/11/14 01:43 AM
S.E. WI
RichL1967 Offline
RichL1967  Offline
S.E. WI
Are you talking about these?
http://www.summitracing.com/parts/hss-23367/overview/make/dodge/model/charger
Hemi71x accidentally had an extra 3 in the number.
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: RichL1967] #1560712
01/20/14 09:35 PM
01/20/14 09:35 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I believe that all the ones for sale are for b-bodys, Not A-bodys.
I would like to know the measurements for the a-bodys. Can any one help?
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: convx4] #1560713
01/20/14 10:51 PM
01/20/14 10:51 PM
hemi71x Offline
hemi71x  Offline
The op is asking about 73-76 A body sway bar mount tabs.
Hotchkis repops those.
In your picture, you have 65-72 LCA's with those sway bar mount tabs on them.
In that regard you are correct, Hotchkis DOES NOT reproduce them.
They repop brackets for the 66-69 B Body line of cars.
And they repop brackets for the 73-76 A bodys, and 70-72 B bodys, 70-74 E bodys, which all are the same bracket.
That should put clarification to this topic.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: convx4] #1560714
01/26/14 08:46 PM
01/26/14 08:46 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
well I didn't get a response to the measurements so I just made them up. What do you think.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms? [Re: convx4] #1560715
01/27/14 01:26 AM
01/27/14 01:26 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They look great, BUT get the sway bar bolted onto the k-member and attach the tabs to the bar with the end links. Put the weight of the car on the tires to locate the tabs properly.
