Marine 318's #1560550
01/07/14 08:07 PM
01/07/14 08:07 PM
pennsylvania
poboyengineering Offline OP
pennsylvania
I just got back from Florida, and my father has a spare 318 out of his shrimp boat. what are the differences in these vs. the car/truck engines? he seems to think they got steel cranks, heavy duty rods, select blocks etc, but he really isn't sure, and ive never been into boats(my favorite ones are the ones that don't sink!). anybody know?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Marine 318's [Re: poboyengineering] #1560551
01/07/14 08:14 PM
01/07/14 08:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I would imagine they are similar to the 273 marine engine. I have a 4 barrel intake for a 273 marine. Intake is a little different than the street manifold.
Re: Marine 318's [Re: dart4forte] #1560552
01/07/14 08:59 PM
01/07/14 08:59 PM
St.Clair Shores, Mich
bryansgarage Offline
More nickle content (to avoid rust)in the block.
Cam and heads suck for street. Watch for left hand rotation motors too.My son's Conqueror 318 jet, needs a marine cam.
My 88 Ramcharger engine is in it and it doesn't like the cam.
Re: Marine 318's [Re: bryansgarage] #1560553
01/07/14 09:09 PM
01/07/14 09:09 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Might be a brass or plastic impeller water pump, but no biggy.
Re: Marine 318's [Re: thehemikid] #1560554
01/07/14 09:56 PM
01/07/14 09:56 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Some were reverse rotation. I had a 340 out of a boat and it had a VIN for a 70 Swinger on it, so it had been replaced at some point.
JB Rhinehart, Realist
A-Body's RULE!
Re: Marine 318's [Re: thehemikid] #1560555
01/07/14 10:03 PM
01/07/14 10:03 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If it's straight inboard. then neither brass nor plastic.
Raw water system has 1 pump that uses a separate, or external, pump that pumped water thru the motor. The standard pump is eliminated. This is the most common system.
Closed system uses 2 pumps, a standard automotive pump that pumps water to a cooler which which is cooled by a raw water pump. This system keeps salt water out of the motor and allows for antifreeze just like automotive, no need for special impellers.
I/O I don't know about.
Re: Marine 318's [Re: poboyengineering] #1560556
01/08/14 02:58 AM
01/08/14 02:58 AM
I worked on one, 318 in a speed boat, reverse rotation/weird firing order. EDIT Same order (sequence) but it did not start with (1)
Re: Marine 318's [Re: RapidRobert] #1560557
01/08/14 03:17 AM
01/08/14 03:17 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Reverse rotation engine can be really fast in reverse. Can the driver?
Re: Marine 318's [Re: mopardamo] #1560558
01/11/14 11:48 AM
01/11/14 11:48 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Reverse rotation firing order is 12756348
