Re: Marine 318's
[Re: thehemikid]
#1560555
01/07/14 10:03 PM
01/07/14 10:03 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Might be a brass or plastic impeller water pump, but no biggy.
If it's straight inboard. then neither brass nor plastic.
Raw water system has 1 pump that uses a separate, or external, pump that pumped water thru the motor. The standard pump is eliminated. This is the most common system.
Closed system uses 2 pumps, a standard automotive pump that pumps water to a cooler which which is cooled by a raw water pump. This system keeps salt water out of the motor and allows for antifreeze just like automotive, no need for special impellers.
I/O I don't know about.
Re: Marine 318's
[Re: poboyengineering]
#1560556
01/08/14 02:58 AM
01/08/14 02:58 AM
RapidRobert
I worked on one, 318 in a speed boat, reverse rotation/weird firing order. EDIT Same order (sequence) but it did not start with (1)
