Re: sub frame connertors [Re: Dons Dart] #1560450
01/08/14 02:53 PM
01/08/14 02:53 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
Just because the car is on stands, doesn't mean the suspension cant be "loaded". It depends on where you place the stands.
When I welded mine in. I ran the front of the car up on ramps, then jacked the rear up and set it on stands, with the stands place under the rear end housing. This way the car is up in the air and you can work under it, but it is setting on the suspension, just as if it were sitting on the ground.
Hope that helps a little. I think some people are thinking that "on stands" means you have them placed under the unibody, with the suspension hanging.
Re: sub frame connertors [Re: MileHighDart] #1560451
01/08/14 03:45 PM
01/08/14 03:45 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
Mine are 1-5/8 c.m. round tube all tied in from the cage above.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: sub frame connertors [Re: 6PKRTSE] #1560452
01/08/14 03:45 PM
01/08/14 03:45 PM
Motor City
Motor City
At the front.
Re: sub frame connertors [Re: 6PKRTSE] #1560453
01/08/14 04:03 PM
01/08/14 04:03 PM
Canada
Dons Dart Offline OP
Canada
very nice.
Re: sub frame connertors [Re: Dons Dart] #1560454
01/08/14 04:55 PM
01/08/14 04:55 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
I used the bolt in style but welded them right off the bat. I didn't want to cut through the floor. I just wanted to stiffen it up, I don't plan on any wheelstands.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: sub frame connertors [Re: gregsrt] #1560455
01/08/14 05:06 PM
01/08/14 05:06 PM
Canada
Canada
I just open the box and did a quick fit,pass side fits great,driver side that emg cable is in the way how do i work around that.Also the instructions say to just jack up the rear and put stands under the axle sounds right to you guys?
Re: sub frame connertors [Re: Dons Dart] #1560456
01/08/14 05:27 PM
01/08/14 05:27 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
As for the emergency brake cable, drill a large hole through the connector on each side but at an angle and weld a pipe in the hole. Mount the connector, then slide the cable through the pipe and reassemble the brake. It worked for me 30 years ago.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: sub frame connertors [Re: MileHighDart] #1560457
01/08/14 05:27 PM
01/08/14 05:27 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Here is your answer.
Re: sub frame connertors [Re: Dons Dart] #1560458
01/08/14 06:04 PM
01/08/14 06:04 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
not sure this will help.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: sub frame connertors [Re: Copper Dart] #1560459
01/08/14 06:10 PM
01/08/14 06:10 PM
Canada
Canada
those are nice but nothing like what i have.
Re: sub frame connertors [Re: gregsrt] #1560460
01/09/14 04:01 AM
01/09/14 04:01 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That's what I did on mine, looks exactly like how yours is done.
Re: sub frame connertors [Re: SNK-EYZ] #1560461
01/10/14 09:53 PM
01/10/14 09:53 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I did this too. I used Comp Engineering connectors and welded them in. I've often thought that I could use steel flatbar stock and scribe it to the floor, cut it to the scribe line, then weld it directly to the floor and to the sides of the connectors to box them in to the floor. Seems like this would be just as strong as "through the floor" without dealing with the carpet and floor lump issues.
