Tail light restoraton #1558999
01/04/14 09:22 PM
01/04/14 09:22 PM
MN
dustyswinger Offline OP
MN
I am begining to restore a pair of 72 Charger rallye tail lights and was wondering what you guys have uesd to replace he lamp sockets. I need 4 1157 sockets for the brake/turn and a pair for 1156 reverse lights. I took out the bad sockets and there is a .750 hole in the housings now. I have seen where people have cut them up and put the newer push in and turn style but am looking for something to just go in the hole..
Next question is what color paint do you use for the housings for the bulbs to reflect off of? Thanks for your help.
Re: Tail light restoraton [Re: dustyswinger] #1559000
01/05/14 08:28 PM
01/05/14 08:28 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Great question.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Tail light restoraton [Re: Copper Dart] #1559001
01/06/14 02:38 AM
01/06/14 02:38 AM
Avondale AZ
Prodart440 Online work
Prodart440  Online Work
Avondale AZ
I can't tell you about the harness, but I used spray chrome for the inside of the housing on my 68 road runner. Turned out real nice (more silver than chrome).
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Tail light restoraton [Re: Prodart440] #1559002
01/06/14 01:51 PM
01/06/14 01:51 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Try "Terminal Supply Co" for the sockets. I also used spray paint "chrome" for the insides of the housing.
Re: Tail light restoraton [Re: burdar] #1559003
01/06/14 02:29 PM
01/06/14 02:29 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
3rd vote for spray chrome in a can. Even in twilight they look pretty bright...just make sure you have a good ground.
Re: Tail light restoraton [Re: dustyswinger] #1559004
01/06/14 02:40 PM
01/06/14 02:40 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
This was a while ago, so there may be other options now...
On a '71 Ply, I used Ford tailight sockets...Di-chromate sockets with a rubber 'shroud' to protect wire-at-socket from the 'elements'...
20 years later, they're doing fine...
Much better set-up than OEM...
(I also sprayed 'chrome' inside the housings)...
Re: Tail light restoraton [Re: RSNOMO] #1559005
01/06/14 03:30 PM
01/06/14 03:30 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Eastwood company has a specific paint to use for this.. Worked great on my car..
Re: Tail light restoraton [Re: floridian] #1559006
01/11/14 03:48 AM
01/11/14 03:48 AM
MN
MN
Thank you for the replies. I went to O'reilly's and found a couple sockets that fit the .750 opening. I haven't had the time to fit them yet but I think they will work just fine.I will try to clean the reflective surface up but if they ar not up to snuff I will use the paint. Thanks again Craig
