coolant system sealers??? #155830
11/24/08 12:51 PM
11/24/08 12:51 PM
California
70SportSatellite Offline OP
super street
super street
California
i tried to edit my other post but it said maximum time reached to edit? anyeway i'm trying to cfix a leak and have limited time. anyone know of any sealers that can be added without flushing the system? i can dump the coolant that's in it now and fill but then it's time to hit the road. then i can drain and fill later. any suggestions? thanks again
Re: coolant system sealers??? [Re: 70SportSatellite] #155831
11/24/08 01:02 PM
11/24/08 01:02 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Try Bars Leak. Available at most autoparts stores. I hear it is preety good.
Re: coolant system sealers??? [Re: moparmojo] #155832
11/24/08 01:04 PM
11/24/08 01:04 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Bars leak or K&W block sealer is the best. Just make sure its the copper looking stuff and not the pellets. the pellets will clog up the system. Make sure its nice and hot before you put it in.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: coolant system sealers??? [Re: 70dart360] #155833
11/24/08 01:37 PM
11/24/08 01:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Prestone makes a stop leak that is nothing more than a bunch of super small carbon fiber strands that stick together around any hole that forms. I have used it as a temporary fix until I had time to fix the problem correctly. You can run it all the time and it doesn't clog up anything or cause any problems.
Re: coolant system sealers??? [Re: 70dart360] #155834
11/24/08 01:38 PM
11/24/08 01:38 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I used the light tan looking pellets they come like 6 to a package, i think they are partly made with crushed walnut shells, anyway they were recomended buy a few folks to stop my rather large leak of coolant out of two exh studs on a 383. They worked great i only used 4 of the six pellets, i was also told GM used these from the factory on some of their problem engines (northstar ect. )
Re: coolant system sealers??? [Re: ademon] #155835
11/24/08 01:49 PM
11/24/08 01:49 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Yep, their reman engines will have the stuff in the coolant passages. Tripped me out the first time I saw that stuff in there.
Re: coolant system sealers??? [Re: 70SportSatellite] #155836
11/24/08 01:53 PM
11/24/08 01:53 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
How bad of a leak, and how far are you going?
Any kind off stop leak works, but to much of it
is not good for the system. Heater core, thermo
stat, water pump will fail or plug up if you use
to much.
Open the cap one notch and bring extra water with
you. You might just make it where you are going, if it's a pin hole leak.
Then fix it without stop leak.
Snap your neck, mega G-force launch, is all I want!
Re: coolant system sealers??? [Re: BDS871Cuda] #155837
11/24/08 02:28 PM
11/24/08 02:28 PM
California
super street
super street
California
ive been given an extra day so im going to k & w it today and let it sit overnight and fill and go first thing in the morning.
