Wiper Linkage Bushings - To Lube or Not to Lube #1558243
01/03/14 12:52 PM
01/03/14 12:52 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
That is the question!
I need a definitive answer on whether to lube these or not. I have a 1973 Charger wiper linkage with the nylon bushing inserts and I have seen people saying different things here. It seems to me you would want to lube as that linkage is very tight dry and squeaky but some have said the linkage will pop out of the bushings if lubed.
I tried to go cheap and bought the assorted Dorman HELP bushings set but the bushing was just a tad too large inside the ball socket and was much easier to press the ball joint into. Of course, it popped right out when I turned the wipers on. I have OEM bushings on the way and I want to get my wipers working again!
Anybody here have an official answer here? Maybe somebody with a FSM or knowledge of what the factory did? I just don't see why this should be so difficult....
Thanks as always!
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: cjskotni] #1558244
01/03/14 01:05 PM
01/03/14 01:05 PM
P
Paul_Fancsali Offline
P
Factory one's I have seen had small dab of white grease in them. I would just wipe grease on pivot so there is some lube. I have never had them come back off if they went in correctly
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: cjskotni] #1558245
01/03/14 02:22 PM
01/03/14 02:22 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I did the ones on my D100, and thought it a good idea to use a little lube, so I dabbed a little poly suspension goo into each one. They were the Dorman ones also.
Almost as soon as I assembled things they popped apart.
So, got another set and they went together dry.
A year later, they are still intact.
It takes gasoline to interest me.
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: VL21] #1558246
01/03/14 02:29 PM
01/03/14 02:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I've always put a thin coat of white lube on the ball. Too much and the linkage will pop loose because the lube won't allow the ball to seat all the way. It's a very tight fit when done right.
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: cjskotni] #1558247
01/03/14 02:33 PM
01/03/14 02:33 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Anything where there is contact(especially involving plastic)is gonna benefit from some lubrication...
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: VL21] #1558248
01/03/14 03:17 PM
01/03/14 03:17 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
From what I could tell the Dorman ones were slightly smaller on the outside and slightly oversized on the inside. I could press the Dorman bushing in and out of the linkage with my fingers....no way even close with the factory bushings. Same thing with the ball joints where I can pop them in and out of those Dorman bushings fairly easily where the factory bushings needed a clamp and socket to press that mess in.
So the Dorman's were close but didn't quite work in my situation...
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: cjskotni] #1558249
01/03/14 03:27 PM
01/03/14 03:27 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: stumpy] #1558250
01/03/14 05:25 PM
01/03/14 05:25 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Just did the wipers on my DD and it only takes a thin film of white lithium grease to do the job.
I used a little too much on one and it kept popping right back out. The grease was keeping the air from escaping the socket so it was just pressurizing the cavity
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: nomore65BelvJim] #1558251
01/03/14 06:49 PM
01/03/14 06:49 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
I drilled a small hole in the middle of the bushing dome so the air and extra lube could flow out.
Re: Wiper Linkage Bushings - To Lube or Not to Lube [Re: RSNOMO] #1558252
01/03/14 08:25 PM
01/03/14 08:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Even Daisy Duke?
- Stu Harmon
