Wiper Linkage Bushings - To Lube or Not to Lube
#1558243
01/03/14 12:52 PM
01/03/14 12:52 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
That is the question! I need a definitive answer on whether to lube these or not. I have a 1973 Charger wiper linkage with the nylon bushing inserts and I have seen people saying different things here. It seems to me you would want to lube as that linkage is very tight dry and squeaky but some have said the linkage will pop out of the bushings if lubed. I tried to go cheap and bought the assorted Dorman HELP bushings set but the bushing was just a tad too large inside the ball socket and was much easier to press the ball joint into. Of course, it popped right out when I turned the wipers on. I have OEM bushings on the way and I want to get my wipers working again! Anybody here have an official answer here? Maybe somebody with a FSM or knowledge of what the factory did? I just don't see why this should be so difficult.... Thanks as always!
Re: Wiper Linkage Bushings - To Lube or Not to Lube
[Re: cjskotni]
#1558245
01/03/14 02:22 PM
01/03/14 02:22 PM
Posts: 1,357 central Florida
VL21
central Florida
I did the ones on my D100, and thought it a good idea to use a little lube, so I dabbed a little poly suspension goo into each one. They were the Dorman ones also. Almost as soon as I assembled things they popped apart. So, got another set and they went together dry. A year later, they are still intact.
It takes gasoline to interest me.
[Re: VL21]
#1558248
01/03/14 03:17 PM
01/03/14 03:17 PM
cjskotni
North Carolina
From what I could tell the Dorman ones were slightly smaller on the outside and slightly oversized on the inside. I could press the Dorman bushing in and out of the linkage with my fingers....no way even close with the factory bushings. Same thing with the ball joints where I can pop them in and out of those Dorman bushings fairly easily where the factory bushings needed a clamp and socket to press that mess in.
So the Dorman's were close but didn't quite work in my situation...
[Re: cjskotni]
#1558249
01/03/14 03:27 PM
01/03/14 03:27 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: stumpy]
#1558250
01/03/14 05:25 PM
01/03/14 05:25 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
I've always put a thin coat of white lube on the ball. Too much and the linkage will pop loose because the lube won't allow the ball to seat all the way. It's a very tight fit when done right.
Just did the wipers on my DD and it only takes a thin film of white lithium grease to do the job. I used a little too much on one and it kept popping right back out. The grease was keeping the air from escaping the socket so it was just pressurizing the cavity
