edelbock sparkplugs ? #1557744
01/02/14 02:43 AM
01/02/14 02:43 AM
grande prairie , ab , canada
68notch Offline OP
68notch  Offline OP
hey guys , just put a set of edelbrock easy street heads on my 77 400 , any sugestions on whats the best sparkplugs I should use ? thanks
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: edelbock sparkplugs ? [Re: 68notch] #1557745
01/02/14 10:23 AM
01/02/14 10:23 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run NGKs.My 440 has Stealths and use the same plugs as Eddys.I ran Autolites and they were OK but just nor right.Went NGK 4 years ago and they are still in it and going strong.Its 12.5 to one and street driven.I believe Mancini has a cross reference chart for heat ranges.Rocky
Chrysler Firepower
Re: edelbock sparkplugs ? [Re: 68notch] #1557746
01/02/14 01:26 PM
01/02/14 01:26 PM
Edlbrock or Indy EZ Street heads? Probally the same plugs will work, I would try either the Autolite # 3924 or the AR3911. I have ran both of those plugs in a low compression pump gas street motor with Eddy RPM and also in the Indy M.W.intake port SR heads I replaced the Eddy RPM heads with
Re: edelbock sparkplugs ? [Re: Cab_Burge] #1557747
01/02/14 03:07 PM
01/02/14 03:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cab try NGKs.I think you will be suprised.They idle better and dont foul.I ran Autolite race plugs and still prefer the NGKs.Plus they are cheaper.Rocky
Chrysler Firepower
Re: edelbock sparkplugs ? [Re: therocks] #1557748
01/03/14 03:45 AM
01/03/14 03:45 AM
68notch Offline OP
68notch  Offline OP
thanks guys , they are edelbrock heads, which ngk plug do I look for ? as in what is the number ? thanks again
Re: edelbock sparkplugs ? [Re: 68notch] #1557749
01/03/14 09:34 AM
01/03/14 09:34 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I run the BK6RE NGK plugs on my Edelbrock. They work for my engine and I wouldn't hesitate on buying them again
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: edelbock sparkplugs ? [Re: Pyper70] #1557750
01/03/14 02:43 PM
01/03/14 02:43 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Autolite 3924's in my Eddy heads on a 10.2:1 470". They've been in there for many miles...never had one foul?? Street driven, pump gas.
Re: edelbock sparkplugs ? [Re: Dcuda69] #1557751
01/04/14 02:45 AM
01/04/14 02:45 AM
68notch Offline OP
68notch  Offline OP
awesome , that's exactely what I was looking for , thanks again guys
Re: edelbock sparkplugs ? [Re: Pyper70] #1557752
01/04/14 12:59 PM
01/04/14 12:59 PM
SE PA
Yellow Fever Offline
SE PA
Sure it's not BKR6E??
Re: edelbock sparkplugs ? [Re: Yellow Fever] #1557753
01/04/14 03:32 PM
01/04/14 03:32 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
It could be who knows...I got the letters and number right...who knows the sequence..
Re: edelbock sparkplugs ? [Re: therocks] #1557754
01/04/14 03:53 PM
01/04/14 03:53 PM
I've try almost, except E3, brand and heat range of spark plugs out there I like a cold plug and a lean tune up with the least amount of total timing needed to make the car go fast and live
Re: edelbock sparkplugs ? [Re: Cab_Burge] #1557755
01/05/14 05:17 AM
01/05/14 05:17 AM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Here is a bulletin put out by NGK on which plugs to use in Eddy heads that I found while doing some searches on this subject.
http://www.ngkplugpro.ca/content/content...linderHeads.pdf
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
