Page 1 of 3 1 2 3
CNC Ported Iron heads #1556987
12/31/13 08:54 PM
12/31/13 08:54 PM
SoCal
Brian Hafliger Offline OP
SoCal
Finally done and happy with this intake port. I'll pour the intake port Thurs.
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556988
12/31/13 08:55 PM
12/31/13 08:55 PM
SoCal
SoCal
2.02 intake valve.
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556989
12/31/13 08:56 PM
12/31/13 08:56 PM
SoCal
SoCal
They flow pretty good for a 2.02 valve!
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556990
12/31/13 09:10 PM
12/31/13 09:10 PM
SoCal
SoCal
.100 68
.200 142
.300 201
.400 249
.500 281
.550 290
.600 296
.650 293
.700 294
28" on a 4.030 bore...4.125 bore added 3 cfm at .500 and 4 cfm at .600 and then went backwards but still flowed 295 cfm at .650 lift.
Brian
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556991
12/31/13 09:34 PM
12/31/13 09:34 PM
Az
Crizila Offline
Crizila  Offline
Az
Looks great Brian and the flow numbers are awesome. Mopar Magnums or aftermarket?
Fastest 300
Re: CNC Ported Iron heads [Re: Crizila] #1556992
12/31/13 09:36 PM
12/31/13 09:36 PM
SoCal
SoCal
Indy iron X heads...both LA and magnum. Thank you!
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556993
12/31/13 09:46 PM
12/31/13 09:46 PM
Az
Crizila Offline
Crizila  Offline
Az
Got a CnC program for the exhaust side too?
Fastest 300
Re: CNC Ported Iron heads [Re: Crizila] #1556994
12/31/13 09:48 PM
12/31/13 09:48 PM
SoCal
SoCal
Ex. really doesn't need it. It will support more power than the Intake will! At least with my VJ and valve in it...;-)
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556995
12/31/13 09:56 PM
12/31/13 09:56 PM
BPE Offline
BPE  Offline
Good Job.
Rod
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556996
12/31/13 10:21 PM
12/31/13 10:21 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Saw the pictures on FB. Had to come see if you posted flownumbers! YYou're such a tease!! Looks like another job well done!!!
Keith
Re: CNC Ported Iron heads [Re: Dunnuck Racing] #1556997
01/01/14 01:04 AM
01/01/14 01:04 AM
SoCal
SoCal
Working on some eddy port programs next
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1556998
01/01/14 03:02 AM
01/01/14 03:02 AM
FastOne Offline
FastOne  Offline
Looks good, what does the air speed sound like on the flow bench?, just right, slow, fast, coarse, manometer staying steady, think you know what I mean
Re: CNC Ported Iron heads [Re: FastOne] #1556999
01/01/14 03:13 AM
01/01/14 03:13 AM
SoCal
SoCal
Port is very stead up to .600 and then is a bit up and down, not horrible though.
Port is pretty smooth actually, very balanced port design
At .700 lift it's not too bad either...just at .630 to .680 it's a bit rough. I can't shape the short turn any better due to water close by.
I'm putting a set on a 392 short block soon with 13:1 and a solid roller so we'll see what she does
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557000
01/01/14 03:24 AM
01/01/14 03:24 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Did you happen to check runner cc?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: CNC Ported Iron heads [Re: pittsburghracer] #1557001
01/01/14 05:29 AM
01/01/14 05:29 AM
Washington
skrews Offline
skrews  Offline
Washington
Looks nice. Whats the min. CSA ? I thought it would be cool if Indy would sell a version of this head with the pushrod hole relocated for offset intake rockers. I suppose that would would cut into their IndyBrock (sorry Josh thats what everybody calls them) sales though.
Re: CNC Ported Iron heads [Re: skrews] #1557002
01/01/14 06:04 PM
01/01/14 06:04 PM
sweden
sshemi Offline
sshemi  Offline
sweden
They can be as good as they want but what are they gonna cost???
Re: CNC Ported Iron heads [Re: sshemi] #1557003
01/01/14 06:26 PM
01/01/14 06:26 PM
SoCal
SoCal
Just as the eddy heads are not a full on race head, neither are these!
I'll have all the info you guys want tomorrow nite. I'm off today and going to enjoy my family. No matter what they cost, they will always be cheaper than ANY other aluminum head out there and they will hold their own...I hope we shall see.
Cost as always will be much cheaper than anything else out there making similar power with better components!!
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557004
01/02/14 10:57 AM
01/02/14 10:57 AM
The Great White North
RAMM Offline
RAMM  Offline
I too am very curious on the price point and how long these take to machine. Brian, What machine are you using? Also-Will this program fit into an EQ casting? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: CNC Ported Iron heads [Re: RAMM] #1557005
01/02/14 05:36 PM
01/02/14 05:36 PM
SoCal
SoCal
I can only give you a price if you let me help with your next EM build
You know, I never thought of that but I'd have to sonic the floor/short turn on the EQ heads to see...maybe? These don't take too long because it's only the intake port.
They're done on a Rottler machine.
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557006
01/02/14 05:37 PM
01/02/14 05:37 PM
SoCal
SoCal
Intake MCA is 2.200 at the pinch.
Intake port poured right at 200cc.
Brian Hafliger
Page 1 of 3 1 2 3
