HEMI Ray Barton crossram VS Indy tunnel ram #1556956
12/31/13 06:59 PM
12/31/13 06:59 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I have a Ray Barton cross ram on a 572 Hemi (made 895 HP @6500) and was wondering how much taller is a Indy tunnel ram and do you think there would be a performance going to a TR
Thanks Brian
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Bishop] #1556957
12/31/13 07:29 PM
12/31/13 07:29 PM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
I had a cross ram on my 512,Change over a 426 intake gain Et and Mph
Ain't nuthin like a HEMI !
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Mulehead] #1556958
12/31/13 07:30 PM
12/31/13 07:30 PM
Mulehead Offline
Mulehead  Offline
two
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Mulehead] #1556959
12/31/13 07:50 PM
12/31/13 07:50 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I wouldn`t expect much of a gain in performance . My 557 " runs fine with a RBRE / single 1050 Dominator set up and is making 875 HP . A LOT easier to tune as well .
$0.02
Happy New Year !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Bishop] #1556960
12/31/13 07:53 PM
12/31/13 07:53 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I can take some measurements if you want....Although its kinda cold out today...like 40mph winds and 18* out, but I have an Indy TR and their -2 single plane intake...I really like the TR, very little porting is needed on those..Mine fits under the hood when I run it with the TR on...But I do have scoop.
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Dragula] #1556961
12/31/13 08:52 PM
12/31/13 08:52 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I have a Sled city Fiberglas AFX Hemi scoop on my 64 just wonder if it will fit under the hood
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Bishop] #1556962
01/01/14 10:13 AM
01/01/14 10:13 AM
pa
572charger Offline
572charger  Offline
pa
it will be close ive got one on my charger and i have a 68 super stock hemi hood scoop on mine it fits under ,but mine is 1" taller scoop , i may be able to measure it to day ,i know the carbs are( 850s)slightly above the hood
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: 572charger] #1556963
01/01/14 01:24 PM
01/01/14 01:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The story on the Barton cr's is that he did a ton of R&D on them only to arrive at an event in California and find all the west coast guys running fabricated tunnel rams with slightly offset carbs and calling them cr's. The NHRA tech guys sided with the fabbed units and that pretty much put an end to the original style cr's. I would suspect the Barton cr is a fully race prepped item. I'm guessing the Indy TR is "out of the box". The Barton cr should easily outperform an out of the box Indy tr.
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Stanton] #1556964
01/01/14 01:33 PM
01/01/14 01:33 PM
Dragula Offline
Dragula  Offline
Depends on the CI and the cam for where your peak comes in at...No one intake is universal..I remeber seeing intakes all lined up at one racers tent. They try all different stuff to get the most out of them at the upper levels.
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Bishop] #1556965
01/04/14 03:37 PM
01/04/14 03:37 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
If RBRE did your motor, I'd talk to them. Think back on just what a x-ram is. Essentially it's a horizontal tunnelram, so the only real benefit, IMO, would be you're straightening out the path of your incoming mixture. Now how much that's worth, I'm guessing would ( as was said) depend on your combo, where the power is made & what you're trying to accomplish.If the car is only a local/bracket car it may not be worth it. If you're going for every last once of HP & ET, then you need to consult with someone that knows your combo & not just gamble on opinions.
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: Bishop] #1556966
01/05/14 03:55 AM
01/05/14 03:55 AM
OHIO
THE GLASS MAN Offline
OHIO
Nice scoop!
Re: HEMI Ray Barton crossram VS Indy tunnel ram [Re: THE GLASS MAN] #1556967
01/05/14 09:22 AM
01/05/14 09:22 AM
pa
572charger Offline
572charger  Offline
pa
my rear carb on the indy hemi tunnel ram sticks out of the hood about 2 1/2 inches to the top of the fuel bowl vent
