Body work question for those 'sperienced. #1556935
12/31/13 06:11 PM
12/31/13 06:11 PM
Lavonia, GA
cjbill Offline OP
cjbill  Offline OP
Lavonia, GA
In continuing to do my underhood clean-up on the '69 300, the driver inner fender has several 3/8" holes from one of the PO's mounting "something" there. Since it is underhood and exposed to higher than normal temps, is it okay to just fill the holes with bondo or use small squares of fiberglass instead before blending and painting?
ex-Ford guy, but Mopars nowadays
Re: Body work question for those 'sperienced. [Re: cjbill] #1556936
12/31/13 06:24 PM
12/31/13 06:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Weld them then finish them off..
I am truckless..
Re: Body work question for those 'sperienced. [Re: 340SHORTY] #1556937
12/31/13 06:30 PM
12/31/13 06:30 PM
Lavonia, GA
cjbill Offline OP
cjbill  Offline OP
Lavonia, GA
Unfortunately, unable to weld.
Re: Body work question for those 'sperienced. [Re: cjbill] #1556938
12/31/13 06:35 PM
12/31/13 06:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Learn
Re: Body work question for those 'sperienced. [Re: Challenger 1] #1556939
12/31/13 06:39 PM
12/31/13 06:39 PM
Lavonia, GA
cjbill Offline OP
cjbill  Offline OP
Lavonia, GA
Learn
Wow, thanks for the advice, folks, just what I was looking for, I can weld, but am unable to at the moment (welder in storage)...let me put it this way, don't WANT to weld.
Re: Body work question for those 'sperienced. [Re: cjbill] #1556940
12/31/13 06:55 PM
12/31/13 06:55 PM
Cincinnati, Ohio
Cincinnati, Ohio
Learn
You even have a welder and don't want to learn?
Re: Body work question for those 'sperienced. [Re: Challenger 1] #1556941
12/31/13 07:00 PM
12/31/13 07:00 PM
Lavonia, GA
cjbill Offline OP
cjbill  Offline OP
Lavonia, GA
No, have a welder, know how (at least basically), but welder in storage about 300 miles away. Stuck right now. Just looking for things that I "can" do right now, instead of sitting on my butt all winter, watching TV, and thinking about doing it.
Re: Body work question for those 'sperienced. [Re: cjbill] #1556942
12/31/13 08:45 PM
12/31/13 08:45 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
In my experience bondo will eventually 'pop' from a filled hole without extra support. If you can get to the underside of the hole, put some fiberglass cloth there and then bondo on top. Another approach (so you're only working on the top side of the panel) is to sink the area around the hole with a hammer, then lay one or two layers of fiberglass, then bondo over the whole thing.
Re: Body work question for those 'sperienced. [Re: Powerflow] #1556943
12/31/13 08:52 PM
12/31/13 08:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Is it possible to fill the holes with the Eastwoods body solder?
Re: Body work question for those 'sperienced. [Re: cjbill] #1556944
12/31/13 10:26 PM
12/31/13 10:26 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Do it right
Find somebody close with a mini mig and weld it,you will be glad you did.
who is that guy?
Re: Body work question for those 'sperienced. [Re: Brian_wo] #1556945
12/31/13 10:34 PM
12/31/13 10:34 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Welding creates rust Use some body epoxy & glue plugs of metal either in or over them
Re: Body work question for those 'sperienced. [Re: BulletBob] #1556946
12/31/13 11:03 PM
12/31/13 11:03 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
There's a guy from Joisey that is a WIZARD at and rattle-can jobs ... he goes through SO MUCH "mud" ... I hear he buys it in 55 gallon drums ....
Re: Body work question for those 'sperienced. [Re: BulletBob] #1556947
12/31/13 11:16 PM
12/31/13 11:16 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
To be a bit more accurate...Welding does not create rust. Improper finishing of the welded metal creates rust.
Either weld the holes or find something else to do under the hood until you are able to borrow a welder or retrieve yours. Anything worth doing is worth doing right and glass or filler is NOT the proper or permanent way to fill those holes.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Body work question for those 'sperienced. [Re: Centerline] #1556948
12/31/13 11:34 PM
12/31/13 11:34 PM
IN
ahy Offline
ahy  Offline
IN
I have cleaned the back and used epoxy to attach a thin piece of sheet metal behind the hole then bondo on the front, also I have "sunk" the hole and used a little bit of fiberglass and epoxy to fill it. Sand it smooth and finish. Both seem to hold up fine. Agree bondo alone won't hold up.
Re: Body work question for those 'sperienced. [Re: cjbill] #1556949
01/01/14 12:00 AM
01/01/14 12:00 AM
Lavonia, GA
cjbill Offline OP
cjbill  Offline OP
Lavonia, GA
Thanks for the advice, all, think I may "try" the bondo thing out on a trial piece of metal first. If I don't like the results, since I am a novice at the whole bondo/fill thing, I'll try to find someone around with a MIG who is willing to attempt it.
Re: Body work question for those 'sperienced. [Re: cjbill] #1556950
01/01/14 04:47 PM
01/01/14 04:47 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Welding is best and you've asked for opinions and got them...Mine would be to use "all-metal" brand filler if you have to go that route...It's not going to pop from the heat... Only advice would be to countersink the hole{which could be seen from the backside depending on the location}...Ballpeen hammer and a socket on the backside would work to do the job.. You'd need to feather the filler out not just fill the hole and sand it flat leaving a distinct line between the metal and filler..
Re: Body work question for those 'sperienced. [Re: Centerline] #1556951
01/01/14 05:44 PM
01/01/14 05:44 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Weld it or leave the holes....anything else is a waste of time IMO.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Body work question for those 'sperienced. [Re: cjbill] #1556952
01/01/14 10:22 PM
01/01/14 10:22 PM
Jacksonville Florida
elitecustombody Offline
I agree with everyone, do what's right,not what's easy. You might be able to get a cheap flux core welder at Harbor Freight.With 25% off coupon it might be around $50 lol! But if you still can not get a welder,use panel bonding adhesive. Many brands on the market like 3M,SEM,Norton,Fusor,Dominion Seal, Wurth,etc.
It works best on ground clean metal.
Re: Body work question for those 'sperienced. [Re: cjbill] #1556953
01/02/14 05:57 PM
01/02/14 05:57 PM
pa.
dan9 Offline
dan9  Offline
pa.
Maybe use a tiger hair type of filler first then finish with a little bondo.
Re: Body work question for those 'sperienced. [Re: dan9] #1556954
01/03/14 05:41 PM
01/03/14 05:41 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
If you fill holes with bondo, the bondo will later soak up moisture and crack through, making it look worse than drilled holes. Bondo is meant to go between metal and layers of paint.
I'll also vote you should weld, or leave them alone.
