big block bracket question
#1556819
12/31/13 01:50 PM
12/31/13 01:50 PM
Posts: 223 Poplar Bluff, Missouri
partfiler69
Still Wondering
Still Wondering
Does anybody know a place to get power steering brackets for an AC equipped big block? I've looked at 440source and classic industries. All I can find are non AC brackets. This is for a 1973 Satellite with a 400. If I have to go junkyard scrounging, what years will interchange? I believe I have to find 73+ brackets, but not 100% sure. Any help is appreciated.
Back from hiatus
Re: big block bracket question
[Re: JohnRR]
#1556821
12/31/13 02:43 PM
12/31/13 02:43 PM
partfiler69
Still Wondering
Still Wondering
Thanks for the tip, John. But their brackets look like the ones that 440source said will not work. I guess I will give them a call after the holidays. From what I've read, if it had AC, the brackets had a different spacing so everything would line up. Here is a pic of what I BELIEVE I need, lol
[Re: partfiler69]
#1556822
12/31/13 05:43 PM
12/31/13 05:43 PM
Posts: 1,567 Ky
jt4406
Ky
My is John RR is right. Here's a pic of my engine, formerly non a/c, but I added a Sanden coompressor to modified factory a/c compressor brackets and used the same power steering pump on run of the mill bb saginaw pump brackets. You will need to change the alternator brackets to a/c style and use crank, wp and idler pulley setup from a bb a/c application. I believe the pic you have is from a truck/motorhome application that hangs the pump down pretty low. Hope this is some help. jess
Yeah, it's hopped up to over 160...
[Re: cjbill]
#1556825
12/31/13 09:05 PM
12/31/13 09:05 PM
partfiler69
Still Wondering
Still Wondering
Thanks for the help, guys. I guess I'll go ahead and order their brackets and see how it fits. I was under the impression that it had to be mounted lower, but I have no clue.
Back from hiatus
[Re: partfiler69]
#1556826
12/31/13 09:15 PM
12/31/13 09:15 PM
Posts: 1,792 Greer, SC
TooMany62s
Greer, SC
I'm using Bouchillon big block brackets for Sanden AC compressor and their brackets for power steering on the same car. Everything fit and works fine.
[Re: partfiler69]
#1556827
01/01/14 05:20 PM
01/01/14 05:20 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I'll ask the stupid question ... Are you looking to have a 1973 CORRECT look under the hood ? You can't just mix and match stuff unfortunately , the pulleys and brackets all need to work together .
If you are after the look of the picture you posted above , or you have most of those parts , then you'll need the 73 brackets , which I don't think is what Bouchillion sells. If all you want is power steering and A/C then order the Bouchillion brackets AND the pulleys they have.
That 73 setup is mostly the smae with or without air , on it is uses the PS as the idler adjustment for the waterpump, earlier setup never had the waterpump and PS on the same belt.
