Trunk Divider Ideas #1556579
12/31/13 01:47 AM
12/31/13 01:47 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
I need to get the trunk divider done on my 64 Dart. I'm not good at sheet metal so I need some ideas on how to make it work. Any knowledge that imparted is greatly appreciated.
Re: Trunk Divider Ideas [Re: dart4forte] #1556580
12/31/13 11:44 AM
12/31/13 11:44 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
are you referring to the panel that goes behind the back seat to divide the trunk from the passenger compartment? they're usually made of a press board type material (similiar to peg board).
Re: Trunk Divider Ideas [Re: mikemee1331] #1556581
12/31/13 02:23 PM
12/31/13 02:23 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Are you intending to make one out of sheetmetal for a race car because of a trunk-mounted battery/fuel cell?
Big sheet of poster board, some flat stock, clecos, and some pop rivets, or nutserts and screw fasteners.
Street car could use a thick poster board if the correct stuff is unavailable, as that's about all they had anyway.
Re: Trunk Divider Ideas [Re: topside] #1556582
12/31/13 03:38 PM
12/31/13 03:38 PM
Mesa, Arizona
Mesa, Arizona
I'm sorry, I have the battery in the trunk so I need to seal the trunk from the passenger compartment
Re: Trunk Divider Ideas [Re: dart4forte] #1556583
12/31/13 03:48 PM
12/31/13 03:48 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Make a template out of posterboard. Cut panel out of sheet aluminum, maybe 1/16" thick.
Re: Trunk Divider Ideas [Re: dart4forte] #1556584
12/31/13 11:30 PM
12/31/13 11:30 PM
As already suggested use cardboard to make a template( I have use two different pieces and then taped them together to transfer them onto the sheet metal ) and then make sure and fit the real trunk divider as tight as possible to eliminate any air holes in case of a fire to help eliminate liting(firing) you up I got called on my rear divider having a 1/4 inch clearances around the rear down bars going through it I filled that gap in with high Temp silicone and moved the fireproof carpet over to eliminate any light shiny through it
