Re: Starting a dormant engine
[Re: cudaboy]
#1555921
12/30/13 05:06 PM
12/30/13 05:06 PM
Posts: 5,163 CT
GTX MATT
CT
It wouldn't hurt to check, but it will be the same as it was when parked.
Pre lube it, and I'd throw fresh plugs in. Maybe check the carb out (although I usually don't bother until after I have it running). If it has points I usually change them out.
[Re: cudaboy]
#1555923
12/30/13 06:53 PM
12/30/13 06:53 PM
RapidRobert
when your (drill) priming it turn it so the rotor is at #6 for a minute then turn it to #8 for a minute so the pass & dr heads can oil. What Cab said I'd pull the plugs & oil the cyls/rings. I would open the carb & see what it looks like in there & then when back together fill the bowls by hand & new plugs as needed.
[Re: RapidRobert]
#1555924
12/30/13 07:07 PM
12/30/13 07:07 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
Put in some zinc additive too. Comp Cams break in oil or similar.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
