71 Charger tach wiring #1555417
12/30/13 12:54 AM
12/30/13 12:54 AM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
Can anyone post a picture showing the tach wire coming through the firewall on a 71 Charger? I'm adding a tach during the resto and it's a car I did not take apart so I want to make sure I run the wire correctly.
Re: 71 Charger tach wiring [Re: 2JcodeChargers] #1555418
12/30/13 10:20 PM
12/30/13 10:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you have a service manual? The tach wire from what I can tell comes off of block 20 of the bulkhead connector, then goes to the tach as a separate wire. There is a yellow acc feed wire that leads from the tach.
Re: 71 Charger tach wiring [Re: 71birdJ68] #1555419
01/01/14 01:50 AM
01/01/14 01:50 AM
2
No, I do not have a 71 service manual. On the 70 and older cars there is a 1/2" dia. hole in the fire wall that the tach harness goes through. I am assuming a 71 is similiar. I want to make sure I drill the hole properly.
Re: 71 Charger tach wiring [Re: 2JcodeChargers] #1555420
01/01/14 12:18 PM
01/01/14 12:18 PM
MarkMcDonald Offline
No hole in the firewall. Goes thru the bulkhead !
Re: 71 Charger tach wiring [Re: 2JcodeChargers] #1555421
01/01/14 02:44 PM
01/01/14 02:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Let me try to get a picture of mine. You need a manual to do this stuff. The tach was an option,and as such was added on with separate wires that weren't in a bundle.Like I said, they just plugged it to block 20. Give me a day, and I will get a picture.
Re: 71 Charger tach wiring [Re: MarkMcDonald] #1555422
01/01/14 03:31 PM
01/01/14 03:31 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yes...
Get yourself a Service Manual...
Re: 71 Charger tach wiring [Re: 2JcodeChargers] #1555423
01/01/14 07:37 PM
01/01/14 07:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Sorry, but after looking at mine, I would have to take the fuse block apart to show the bulkhead connector. Go over to the Road Runner Nest forum, and see if anybody has theirs apart.
Re: 71 Charger tach wiring [Re: 71birdJ68] #1555424
01/02/14 12:48 AM
01/02/14 12:48 AM
2
No worries. Since it feeds through the block I will get a schematic and route it properly. I am getting close to getting the engine compartment painted and I wanted to drill any needed holes before paint. It sounds like I don't have to worry about any extra holes.
Thanks for the info.
