Can't get the rear wheel off my dually #1555278
12/29/13 06:31 PM
12/29/13 06:31 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
I've tried everything from tapping with a hammer prying with a 2X4 to running the truck back and forth with only 3 lug nuts
It's a 2005 3500 Ram
Re: Can't get the rear wheel off my dually [Re: 52savoy] #1555279
12/29/13 06:42 PM
12/29/13 06:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Aluminum rims?...if so, use a small hand held propane torch and lightly heat the center around the lugs, then, a few swift kicks to each side of the tire should knock it off, I just got through doing this on my Bosses truck a few weeks ago when the "big guy" couldn't change his own flat
Re: Can't get the rear wheel off my dually [Re: DAYCLONA] #1555280
12/29/13 06:49 PM
12/29/13 06:49 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Leave a couple nuts loose and, here’s the key, go around a corner or two. Side loading the wheel will break it loose.
Re: Can't get the rear wheel off my dually [Re: DAYCLONA] #1555281
12/29/13 06:54 PM
12/29/13 06:54 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
naa... steel rims. 64post.. I was just over at the Cummin's forum and that's what was suggested there ..figure8s.
The only thing around my house are straight country roads. I'll have to drive a couple miles with loose lugnuts to find a parking lot.
Re: Can't get the rear wheel off my dually [Re: 52savoy] #1555282
12/29/13 06:56 PM
12/29/13 06:56 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Can't get the rear wheel off my dually [Re: 52savoy] #1555283
12/29/13 06:58 PM
12/29/13 06:58 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The only thing around my house are straight country roads. I’ll have to drive a couple miles with loose lugnuts to find a parking lot.
Can’t just do a u-turn from you driveway onto the road then back to the garage? I’d try this first before going miles up the road.
My left rear wheel was “welded” on and I only had to make to 2 low speed right turns.
Re: Can't get the rear wheel off my dually [Re: 64Post] #1555284
12/29/13 07:00 PM
12/29/13 07:00 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
I'll try it first.. If that doesn't work then I'm on a "death race"
Re: Can't get the rear wheel off my dually [Re: 52savoy] #1555285
12/29/13 07:01 PM
12/29/13 07:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
May I suggest
spinach
Don't be the exception.
Re: Can't get the rear wheel off my dually [Re: 52savoy] #1555286
12/29/13 07:02 PM
12/29/13 07:02 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'll try it first.. If that doesn’t work then I'm on a "death race"
Try a couple of right and left turns and make sure the nuts are loose enough to allow the rims to walk off a bit. I backed mine off finger tight plus 2-3 revolutions.
Re: Can't get the rear wheel off my dually [Re: 64Post] #1555287
12/29/13 07:40 PM
12/29/13 07:40 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
I did a few turns in my driveway but it didn't budge so I went down the road about a mile and made a left turn... It came loose
Now the work begins.. replacing a bad rotor. I was thinking about changing them both even though only one is chewed up
Re: Can't get the rear wheel off my dually [Re: 52savoy] #1555288
12/29/13 07:48 PM
12/29/13 07:48 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Re: Can't get the rear wheel off my dually [Re: 64Post] #1555289
12/29/13 07:58 PM
12/29/13 07:58 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
Thank you
