Well, I was warned. 47RE help * UPDATE**
#1555048
12/29/13 12:13 PM
12/29/13 12:13 PM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
My '02 3500 Ram turned 50K recently and I thought it would be a good idea to change fluid and install a shift kit. I've let it be known I didn't care for how this thing shifted from day 1 and had it to the dealer a couple times. It seems to want to hunt for gears when towing or when in cruise would downshift for a grade then never upshift on it's own when on a flat.( I let it go for miles just to see when) Anyway most of this stuff was cured when I turn the OD off. Enough history for now. I installed this Trans-Go kit and followed the directions as best I could and now have a problem with 1-2 shift. From a cold start seems ok but as the trans warms it acts up. What I thought was slipping is it wanting to start in 2nd gear. Stopping then going to reverse then back to drive seems to correct it but will flutter between 1 & 2 depending on throttle position. Idleing thru a parking lot I can hear it shifting in and out of 1st but don't really feel it. Occasionally from a dead stop it will shift normal. 3rd, OD, and convertor lock-up seem normal. By the time I had disassembled the VB on my bench I wished I had paid someone to do it but it was too late. I'm only assuming it has something to do with the 1-2 accumulator but don't know the full mechanics of any of it. Typing this all out is easier than trying to explain this over the phone to someone. I am embarrassed this didn't work out and could really use a little guidance.
Re: Well, I was warned. 47RE help
[Re: OldMoparMan]
#1555059
12/30/13 07:49 PM
12/30/13 07:49 PM
redraptor
Greenville, PA
Lastly what did the oil look like when you drained it the first time.
It was fine. It does have the plastic piston. But I didn't have the 1-2 shift problem. I have rebuilt a couple of 727's and a turbo 400 so I thought I could handle it. I will double check my work and if I can't resolve it will have to take it somewhere. Thanks everyone for your responses.
Re: Well, I was warned. 47RE help *UPDATE**
[Re: 71yelladustr]
#1555061
01/01/14 12:01 PM
01/01/14 12:01 PM
redraptor
Greenville, PA
ASSuming everything in the shift kit was installed correctly,
Yes, my incompetence lead to this problem. So yesterday I had FREE time (No wife, kids, or grandkids, or any other distractions.) to tear it down and go over the directions and I HAD in fact missed a couple steps. A reducer/spring/checkball behind the OD accumulator housing and drilling a hole in the lower valve body plate. I originally reused the large VB plate as I thought it had the enlarged suction hole. If it were bigger how would it seal? Oh well, from what little I drove it the checkball by the 1-2 accumulator was pushing thru the plate. I also noticed before that one of the 2-3 holes was way larger than the other on my original plate, like larger than recommended to drill. Anyway, it's a totally different animal now and can't wait to tow to see the shift points. Thanks again everyone for listening to my problems and your suggestions.
[Re: redraptor]
#1555062
01/01/14 05:26 PM
01/01/14 05:26 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Took a severe beating with a 2wd ram 1500 version of this unit years ago.Used that super duper canadian major VB modification deal. had the pan off like 5 times, the thing that I missed that got it all happy again was the (hope I say this right)pressure regulator and pressure sensor located on the side of the VB.If the trans gets the slightest bit of dirt in either of these (ie fluid a little burnt)it will NEVER work right.in desperation I contacted a well known trans rebuilder in AZ or Nevada I think and bought those 2 parts for like $75. easy install and the truck is still driving, albeit not perfect, but usable.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
