Valve choice for street 360. Why not a poll? #1554790
12/28/13 05:30 PM
12/28/13 05:30 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
In getting ready to have my heads worked on I am trying to decide what kind of valves to buy. The engine will be a stock stroke 360, with a cam in the 220@.050 .510 lift range. The heads are 308's I am going to have some mild port work done on and opened up to 2.02 intake size. The donor was pretty high mileage so I am sure the guides need replacing anyway.
Hughes 11/32??? (HUGHES 1006/1013) The intake seems to have even more of a step down on the stem, and the exhaust has a pronounced tulip which I've read the 308 port responds well to. Is there a real benefit to 11/32 stems? I know they are lighter but this will not be a high revving race mill.
Mildon Megaflow 3/8??? (MILODON 45215/45225) Both valves have undercut stems, and do not appear to have a ski-jump that would need back cutting. Would there be any benefit to 3/8 stems wear/stability in the guide? Could I run "normal" umbrella seals at that lift? Thinking easier replacement / come in gasket sets for service later down the road.
Any other options??? Mopar Performance valves look to be about twice the cost of the Milodon. Anyone else I should be looking at? Kind of leaning towards the Hughes parts as I type this out.
Best valves for A Street Car Named Melissa
single choice
Votes accepted starting: 12/28/13 03:29 PM
You must vote before you can view the results of this poll.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Valve choice for street 360. Why not a poll? [Re: Michael Ecks] #1554791
12/28/13 05:42 PM
12/28/13 05:42 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
It's hard to go wrong with PBM's for the money. I wouldn't be surprised if that's what Hughes is selling under their brand name. Just get .100 longer Chevy 2.02's or 2.05's in 11/32 stem.
Re: Valve choice for street 360. Why not a poll? [Re: 5spdcuda] #1554792
12/28/13 06:51 PM
12/28/13 06:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think you are over complicating that build. I have run stock valves with more cam than that with no problems. so any aftermarket valve will be a step up.unless it's chinese garbage
Re: Valve choice for street 360. Why not a poll? [Re: Quicktree] #1554793
12/28/13 07:04 PM
12/28/13 07:04 PM
Columbus, GA
Columbus, GA
HAHAHA, I almost made "you're over complicating it" a fifth choice. I don't mind spending a little money on this build, but I can't build a new one every other year. The last engine I built for this car lasted 20 years and probably 200,000 miles. I just want to make sure that the parts will last and I will be happy with the results for a long time to come.
Re: Valve choice for street 360. Why not a poll? [Re: Michael Ecks] #1554794
12/28/13 07:32 PM
12/28/13 07:32 PM
Renton Washington
Triple Threat Offline
Renton Washington
I have friends who have broke the chinese Hughes valves, run far far away. Mopar performance you're paying for a name, not really added value.
I would opt for Manley or Ferrea.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Valve choice for street 360. Why not a poll? [Re: Triple Threat] #1554795
12/28/13 08:58 PM
12/28/13 08:58 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
with TT
Plymouth Makes It!
Re: Valve choice for street 360. Why not a poll? [Re: RoadRunnerLuva] #1554796
12/28/13 09:22 PM
12/28/13 09:22 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I usually pay around 140-150 dollars for (8) Ferera valves off ebay when I go to a bigger valve in some of the heads I work on. pretty cheap insurance.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Valve choice for street 360. Why not a poll? [Re: Michael Ecks] #1554797
12/28/13 09:27 PM
12/28/13 09:27 PM
Locomotion Offline
Locomotion  Offline
You need to watch the overall length of the valves to avoid complicating rocker geometry and spring installed height. The ones you mentioned are +.070". Longer valves are normally used to accommodate valve springs and lifts much higher than you will be using.
Milodon has a standard "Street" stainless valves that should fit the bill. ( 45640/45645 ) All of their stainless valves are manufactured in Argentina, which is good! I have heard many manufacturers use Argentina as their source.
Re: Valve choice for street 360. Why not a poll? [Re: pittsburghracer] #1554798
12/28/13 09:52 PM
12/28/13 09:52 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Re: Valve choice for street 360. Why not a poll? [Re: mopartoby] #1554799
12/28/13 10:21 PM
12/28/13 10:21 PM
NC
barracuda man Offline
NC
I use the stainless ones that Mancini sells.Never had a problem.Plus i have a brand new set for sale.
Re: Valve choice for street 360. Why not a poll? [Re: Locomotion] #1554800
12/28/13 11:54 PM
12/28/13 11:54 PM
Ohio
moparjoe360.4 Offline
Ohio
I'm running the Milodon Street stainless exhaust valves. I've got 10k mi and 150-200 passes on my 360 and it just ran a new best in September. I've been kicking around the idea of putting 2.02s in the heads this winter and I plan to use the intakes if I do. I don't think you can beat them for the money.
Re: Valve choice for street 360. Why not a poll? [Re: Michael Ecks] #1554801
12/28/13 11:55 PM
12/28/13 11:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A Street 360?, yes IMO, you are overcomplicating, besides, you will likely step up to alum heads, anyway, so just send them to hughes, do a minor bowl/port/valve job,let them ponder the SS valve choice, give them a credit card, and focus on something else.
Re: Valve choice for street 360. Why not a poll? [Re: jcc] #1554802
12/29/13 10:50 AM
12/29/13 10:50 AM
408Dust Offline
408Dust  Offline
Your poll is broken there is no none of the above buttons.
Re: Valve choice for street 360. Why not a poll? [Re: 408Dust] #1554803
12/29/13 12:57 PM
12/29/13 12:57 PM
Columbus, GA
Columbus, GA
Kind of where I was going with 4) "Get something else" which seems to won out anyway.
I've seen deals on Ferrea on Ebay, but ever since I saw the article on counterfeit peformance parts I've decided to stick with what I can get new from places like Summit, Jegs, and Hughes.
I think I am going to go with the Milodon Street Stainless option that seems to have gotten a few thumbs up here. Good catch by Locomotion on the overall length of the Mega-Flows I was looking at .
I may be over complicating a little but I tend to overbuild everything I make, just how I was taught by my mentors. With 20yrs/200,000K of street abuse on my last build I don't think is a bad thing.
Thanks for pointing me in the right direction guys!
