New Springs and Shocks on My Charger, Now It Handles Like a Truck #1554371
12/27/13 11:10 PM
12/27/13 11:10 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
Stock replacement springs and Monroe gas shocks. I am NOT using SS springs but the car is still sitting a bit high. Im sure it will drop a bit but will the handling flatten out as they settle? Its very bouncy and top-heavy feeling.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RangerDan440] #1554372
12/27/13 11:30 PM
12/27/13 11:30 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I've got OEM spring packs with one leaf added per side...
Along with Monroe gas shocks...
It's still 'firm' after 20 years...
But that's with all urethane, and front and rear sway bars...
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RSNOMO] #1554373
12/28/13 12:18 AM
12/28/13 12:18 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
When you tightened the spring to hangar, and shackle bushing bolts, did you have the car setting with its weight on it, or did you still have it on jack stands?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: hp383] #1554374
12/28/13 02:18 AM
12/28/13 02:18 AM
IN
ahy Offline
ahy  Offline
IN
The springs should settle with some driving - at least mine always have. If the top heavy feeling is caused by rear ride height settling will help.
I still wonder why it feels so bad. Did it drive better with the old parts? Were old parts stock or stock replacement? Monroe shocks, stock replacement springs and "rides like a truck" suggests something else is going on.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: ahy] #1554375
12/28/13 04:37 PM
12/28/13 04:37 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Well, process of elimination is one path, can you easily re install the old shocks, no matter what condition they are in and test ride? Not so much they will fix the problem as much as narrow down the problem.
Second thought, maybe visit HD and get 5 bags of sand
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RangerDan440] #1554376
12/28/13 05:21 PM
12/28/13 05:21 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
ss springs are not bouncy,so im not sure where that came from,maybe height factor.bouncy would be a shock issue.how much higher is the rear with these new springs?
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: mcmopars] #1554377
12/28/13 05:25 PM
12/28/13 05:25 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
does it ride like a truck(stiff,=heavy spring)or bouncy?
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: mcmopars] #1554378
12/28/13 06:42 PM
12/28/13 06:42 PM
bouncy
I use the same Monroe shocks in all of my old cars and never have they felt like this before. I guess they could be a bad set though.
The car is sitting a lot higher than it did before, which is to be expected and I realize it will drop somewhat in the next couple of weeks. The old springs were worn and it was squatting a lot. I'll take a picture the next time I go outside and show what it looks like now. It actually looks 70s street machine cool but will look better (and hopefully ride better) as it drops
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RangerDan440] #1554379
12/29/13 02:28 AM
12/29/13 02:28 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Are the shackles in their correct position?
It is possible with a new spring install to pull the shackle over center and flip them forward instead of backwards. This results in an increased ride height and the inability to move backwards will make the ride feel very harsh.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: TC@HP2] #1554380
12/29/13 12:32 PM
12/29/13 12:32 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Interesting, guess anything is possible
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: jcc] #1554381
12/30/13 03:19 PM
12/30/13 03:19 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Yeah, did it once myself. That's how I know it can happen and the ride results of it absolutely suck.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: TC@HP2] #1554382
12/31/13 01:23 AM
12/31/13 01:23 AM
I checked the shackles, they are on correct. (yall had me second guessing ) I did the springs 2 weeks ago and the car is already starting to squat more and feel a little more planted so maybe Im just jumping the gun a bit.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RangerDan440] #1554383
12/31/13 03:07 PM
12/31/13 03:07 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Reason I reused my original springs ( took em apart, painted and installed new zinc and the plastic part) Wanted more of a lowered look..
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: floridian] #1554384
01/03/14 02:13 AM
01/03/14 02:13 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
The last set of springs I bought never settled at all. You can flip the front mounts and get some drop that way. If they are still too high find a good spring shop locally and ask them to "de-arch" the springs. Just Suspension was also carrying three way adjustable shackles.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RangerDan440] #1554385
01/03/14 08:34 PM
01/03/14 08:34 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
When we replaced the springs on the hot rod the new ones were too long. The extra length caused the springs to arch excessively and the suspension bounced.
I ended up taking the springs apart and using the new stack on the old main leaf. It made for a nice SS style spring.
- Stu Harmon
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: feets] #1554386
01/04/14 12:37 AM
01/04/14 12:37 AM
NY NY
3
340duster340 Offline
NY NY
i have the opposite problem, the new springs on my 66 dart are dead flat, when installed right out of the box. to me they are low, but i like the look. just worried about when/if they actually settle.
in any case, i have also always run monroe shocks on all my cars (reasonably priced and good for my purposes), if its too bouncy or too stiff, i would start with the shocks.
Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck [Re: RangerDan440] #1554387
01/04/14 04:34 PM
01/04/14 04:34 PM
Ozona, Texas
P
Paladin Offline
Paladin  Offline
P
Ozona, Texas
Should make you feel right at home after riding around in those Coast Guard cutters.
Happy New Year, McSweeney
