Re: New Springs and Shocks on My Charger, Now It Handles Like a Truck
[Re: RSNOMO]
#1554373
12/28/13 12:18 AM
12/28/13 12:18 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
When you tightened the spring to hangar, and shackle bushing bolts, did you have the car setting with its weight on it, or did you still have it on jack stands?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: ahy]
#1554375
12/28/13 04:37 PM
12/28/13 04:37 PM
Posts: 22,730 Bitopia
jcc
Bitopia
Well, process of elimination is one path, can you easily re install the old shocks, no matter what condition they are in and test ride? Not so much they will fix the problem as much as narrow down the problem. Second thought, maybe visit HD and get 5 bags of sand ![](/ubbthreads/images/graemlins/grin.gif)
[Re: mcmopars]
#1554377
12/28/13 05:25 PM
12/28/13 05:25 PM
Posts: 1,012 indiana
mcmopars
indiana
ss springs are not bouncy,so im not sure where that came from,maybe height factor.bouncy would be a shock issue.how much higher is the rear with these new springs?
does it ride like a truck(stiff,=heavy spring)or bouncy?
[Re: RangerDan440]
#1554385
01/03/14 08:34 PM
01/03/14 08:34 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
When we replaced the springs on the hot rod the new ones were too long. The extra length caused the springs to arch excessively and the suspension bounced.
I ended up taking the springs apart and using the new stack on the old main leaf. It made for a nice SS style spring.
[Re: RangerDan440]
#1554387
01/04/14 04:34 PM
01/04/14 04:34 PM
Posts: 397 Ozona, Texas
Paladin
Ozona, Texas
Should make you feel right at home after riding around in those Coast Guard cutters. Happy New Year, McSweeney ![](/ubbthreads/images/graemlins/biggrin.gif)
