Not turning over ! #155395
11/23/08 06:18 PM
11/23/08 06:18 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
My middle brother has a 1973 Dodge Challenger. Well he got in an incident a mile from where he brought the car. We limped the car home. After the car was repaired we started having starting issues. So we put on new battery cables, ignition box, and starter. Well the headlights and radio work (so we got power). But when you try to start the car it just clicks ? It doesn't even turn over !
Re: Not turning over ! [Re: 440727] #155396
11/23/08 06:37 PM
11/23/08 06:37 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
since you replaced the cables, that should take care of dirty connections. make sure they are correct, and tight. make sure the battery has a good charge. after that, might be a bad starter or relay.
1981 Dodge D150 360 auto
Re: Not turning over ! [Re: basketcase] #155397
11/23/08 06:41 PM
11/23/08 06:41 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Where is the starter relays at on a E body ?
Re: Not turning over ! [Re: 440727] #155398
11/23/08 06:41 PM
11/23/08 06:41 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
drivers side inner fender, right next to the battery.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Not turning over ! [Re: GoodysGotaCuda] #155399
11/23/08 07:10 PM
11/23/08 07:10 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
If its clicking the relay is getting power and working. Sounds like the starter cables connections or a stuck starter.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Not turning over ! [Re: 440727] #155400
11/23/08 09:49 PM
11/23/08 09:49 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
What condition is the battery in?
What kind of "incident" occurred?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Not turning over ! [Re: 340727dart] #155401
11/23/08 11:38 PM
11/23/08 11:38 PM
on the starter itself with a screwdriver jump from the large(batt) terminal to the small (solenoid) terminal. Be careful not to touch the screwdriver to the starter body. If it cranks the starter is obviously good so go up to the relay & with the screwdriver jump from the large (batt) terminal to the fairly large brown WIRE that goes down to the starter. If it cranks plug the brown wire back onto its terminal & take off the neutral safety switch WIRE on the starter relay & ID it as it is plugged on a male terminal that says "grn" on the brown face of the neutral safety switch & ground the male TERMINAL on the relay with a jumper wire to GROUND & see if it cranks with the ign key.
Re: Not turning over ! [Re: RapidRobert] #155402
11/25/08 07:44 PM
11/25/08 07:44 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Thanks gunna try that tomorrow
