Re: Not turning over !
[Re: 440727]
#155396
11/23/08 06:37 PM
11/23/08 06:37 PM
Posts: 7,832 east side of Ohio
basketcase
east side of Ohio
since you replaced the cables, that should take care of dirty connections. make sure they are correct, and tight. make sure the battery has a good charge. after that, might be a bad starter or relay.
1981 Dodge D150 360 auto
[Re: 440727]
#155398
11/23/08 06:41 PM
11/23/08 06:41 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Where is the starter relays at on a E body ?
drivers side inner fender, right next to the battery.
[Re: GoodysGotaCuda]
#155399
11/23/08 07:10 PM
11/23/08 07:10 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
If its clicking the relay is getting power and working. Sounds like the starter cables connections or a stuck starter.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 440727]
#155400
11/23/08 09:49 PM
11/23/08 09:49 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
What condition is the battery in? What kind of "incident" occurred?
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: 340727dart]
#155401
11/23/08 11:38 PM
11/23/08 11:38 PM
RapidRobert
on the starter itself with a screwdriver jump from the large(batt) terminal to the small (solenoid) terminal. Be careful not to touch the screwdriver to the starter body. If it cranks the starter is obviously good so go up to the relay & with the screwdriver jump from the large (batt) terminal to the fairly large brown WIRE that goes down to the starter. If it cranks plug the brown wire back onto its terminal & take off the neutral safety switch WIRE on the starter relay & ID it as it is plugged on a male terminal that says "grn" on the brown face of the neutral safety switch & ground the male TERMINAL on the relay with a jumper wire to GROUND & see if it cranks with the ign key.
