engine installation bummer #155369
11/23/08 06:16 PM
11/23/08 06:16 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
First try today on putting the 318 engine back into the satellite ended in failure.
3 hours and no cigar.
kept hanging up on the bell house
any words of wisdom would be greatly appreciated
Re: engine installation bummer [Re: Rick57] #155370
11/23/08 06:53 PM
11/23/08 06:53 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Make sure the convertor is all the way in the trans (if auto). Take some old bellhousing bolts (I think they are 7/16") and cut the heads off, slot them so you can put a screw driver in the slot and put them in the block at about 3 and 9 o'clock. They will guide the block on the bell housing. Insert some bolts, then remove the studs with a screwdriver.
Re: engine installation bummer [Re: Kevins493] #155371
11/23/08 07:34 PM
11/23/08 07:34 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Is the tranny just hanging or do you have it jacked up too?
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: engine installation bummer [Re: 70dart360] #155372
11/23/08 07:44 PM
11/23/08 07:44 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Get another jack slide it under the transmission pan and use it to carefully manipulate the transmission up or down to match the angle of the engine. I hope you have the engine hanging from something that allows you to tilt it.
Re: engine installation bummer [Re: Rick57] #155373
11/23/08 07:56 PM
11/23/08 07:56 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Believe it or not. Raise the rear of the car. It will help with the angle when installing the engine.
Good luck.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: engine installation bummer [Re: Neil] #155374
11/23/08 09:50 PM
11/23/08 09:50 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
I wqas only using a lifting plate. Not much of an angle. Does angling the engine with an engine leveler make a big difference.
Re: engine installation bummer [Re: Rick57] #155375
11/23/08 10:28 PM
11/23/08 10:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have never done it without one and don't think I would want to. I suppose you could do it if you had some friends to help push the engine around as needed while someone layed underneath and got the bellhousing bolts started.
Buy or borrow and engine tilter and give it another try.
Re: engine installation bummer [Re: Neil] #155376
11/23/08 10:32 PM
11/23/08 10:32 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
Neil
will do that is my next attempt
bummer to have an engine on the garage floor just waiting to be home
Re: engine installation bummer [Re: Rick57] #155377
11/23/08 10:33 PM
11/23/08 10:33 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Because I don't know you from Joe Blow. The converter is not on the flexplate but in the transmission right?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: engine installation bummer [Re: HealthServices] #155378
11/23/08 10:36 PM
11/23/08 10:36 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
Yes stall converter is on the transmission spindle. The satellite has a 904 and I bought a 2200-2500 stall. I think I have it push as far on as I can. It turns freely and I can hear the transmission when I spin it around.
Re: engine installation bummer [Re: HealthServices] #155379
11/23/08 10:37 PM
11/23/08 10:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have one of these and it works nice.
http://www.myks-tools.com/
These are more common and work fine also.
http://store.summitracing.com/egnsearch....e&N=700+115
Re: engine installation bummer [Re: Neil] #155380
11/23/08 10:42 PM
11/23/08 10:42 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
Thanks Neil
Re: engine installation bummer [Re: Rick57] #155381
11/23/08 10:50 PM
11/23/08 10:50 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I always install engine and trans together.
Raise the rear of as much as your floor jack goes, lifting under the rear diff.
Don't forget your safety stands.
This way I can get it done on my own but it's nice to have extra hands, then I don't have to get under it to do any wiggling.
Re: engine installation bummer [Re: Rick57] #155382
11/24/08 01:00 AM
11/24/08 01:00 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
The convertor must "drop" in 3 times.
If it hasnt, its not in correctly.
There are different year convertors, and transmissions that wont match up(I forget the years, didnt they change in '66?)
Moons ago, I attempted to install a '77 convertor into a '66 trans, never could get it bolted together. 'Course, I was 17 at the time and didnt know any better.
Re: engine installation bummer [Re: NTOLERANCE] #155383
11/24/08 01:51 AM
11/24/08 01:51 AM
Townsville
3
3_wheelie Offline
3_wheelie  Offline
Townsville
I installed a small block into my car not but a few weeks ago by myself. I had a juck under the bellhousing so i could adjust the tranny it to where i wanted it, had the engine mounts and radiator removed also. Just using a lift plate it was a breeze
YutKillYut Grozny lives!
Re: engine installation bummer [Re: Rick57] #155384
11/24/08 10:06 AM
11/24/08 10:06 AM
MNobody Offline
MNobody  Offline
Well, i guess i'm old but we used a chain bolted cross corner on the intake with longer bolt's so we could adjust the angle of the motor by hooking the picker to different link's on the chain. Sound's like you need a steeper angle to get the motor in.
