Re: spark plug wires for a 440
[Re: watsonpoint]
#1553677
12/26/13 10:38 PM
12/26/13 10:38 PM
RapidRobert
I always thought the less resistance the better (solid wire cores) but people have stated that it ain't as simple as that & also I've seen that Firecore wires get regular rave reviews on here. I'm not convinced. EDIT They ain't cheap tho
[Re: RapidRobert]
#1553678
12/26/13 11:22 PM
12/26/13 11:22 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We run Taylor Spiro Pros on all our cars.Mine with 2 inch headers have been on at least 14 years.My kids 2 1/8 tubes have been on for 8 years.We have ran them on stock manifolds and headers with no problems.I even had them on my 57.We use the ones for stock BBs and or SBs.Have them on the Harleys that we made from extra coil wires.Rocky
Chrysler Firepower
[Re: GY3]
#1553680
12/27/13 02:30 AM
12/27/13 02:30 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Firecores work well, and the stock ones are matched well with numbers for easy installment. I love them on my 440. Mike
1969 Dodge Dart Swinger
[Re: ahy]
#1553682
12/27/13 10:38 AM
12/27/13 10:38 AM
therocks
Niles , Ohio
If you burnt the Taylors something was wrong.My kids 62 300 with 2 1/8 tubes and PS hasnt burnt them in 8 years.He does run a boot cover on #7 cyl as the headers are so large.My 65 has no ps and the fit is tight with a 440 and 2 inch tubes.Taylors have been on at least 12 to 14 years.Still pliable and no burns.Rocky
Chrysler Firepower
[Re: watsonpoint]
#1553683
12/27/13 07:58 PM
12/27/13 07:58 PM
Posts: 85 Lavonia, GA
cjbill
Lavonia, GA
I've had good luck (in the past) with the Summit universal 8mm sets, and a set of spark plug heat boots. My apps weren't Mopar, but a '79 Ranchero and '88 T-Bird, both with 460's and big 2" full-length headers. The "custom fit" sets never seemed to have the lengths dead-on for those apps, and that irked me. Can't beat the price, about $50 total.
ex-Ford guy, but Mopars nowadays
[Re: cjbill]
#1553684
12/28/13 04:49 AM
12/28/13 04:49 AM
Posts: 40 Santa Cruz, Ca
4woody
Santa Cruz, Ca
I was using MSD Streetfire Wires on my 383-powered, electronic ignition, project- which has some header clearance issues. They are a made in USA, 8mm, black. universal fit set. Cost about $35 at Summit.
Unfortunately I cut one wire a little short, and wanted to redo my coil wire with straight boots/terminals instead of the 90 degree ones that came with my kit anyway.
Autozone was on the way home from work. I usually expect the cheapest of the worst from them, and was expecting to buy a single wire along with boots and terminals for the coil wire.
I ended up buying a complete set of Duralast #1601 cut-to-fit wires (90 degree dizzy & plug boots, straight coil wire boots, plain black rubber, 8mm, 2 year warranty) that are made in USA and look an awful lot like my MSD's. For $15 the set.
I was very pleasantly surprised at both the quality and price. Unless they turn out to have some hidden flaw these should be real popular with the budget-minded rodder.
FWIW Duralast #1600 is the same wire set but with straight plug boots, and both sets come with terminals for both HEI & socket style dizzys.
They've been on a year now, and are still doing fine
[Re: cjbill]
#1553687
12/28/13 05:35 PM
12/28/13 05:35 PM
therocks
Niles , Ohio
Just dont use the red house wires from AZ.We installed some sets at work.Within a few months all were arcing.We did and I still do use a lot of Autolite wires for stock apps.Rocky
Chrysler Firepower
[Re: watsonpoint]
#1553691
12/30/13 07:14 PM
12/30/13 07:14 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Hello. What manufacture headers will you be using? In using headers, it will be difficult to use most of the stock wire looms.
What about the Firecores are you you not convinced about? I can answer any and all questions. Thank you.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
